1975 2.7 running to hot timing problem????
running hot can't seem to get the timing marks to line up without the distributor rotated all the way clockwise, if the cam timing was off would it start so easily and run correctly??
Caveman Hammer Mechanic
Mine ran hot until I added a fender mounted cooler.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
You’re distributor is one cog off inside the motor.
Set Z1 on #1 cylinder Remove nut on dist. Lift up until the rotor is free to spin. The rotor turns clockwise. Reset rotor to leading edge lines with mark on edge of the distributor. Reset the dist. You should line up with more adjustment available. Bruce |
too hot
Have already rotated the drive gear and to get it timed the dizzy has to be rotated to the opposite end of the adjustment range |
Well, you went one too many teeth.
Bruce |
76 911S Targa
Mine ran really hot when I first got it. The timing was retarded, the fuel mixture was off, some air hoses were loose allowing cooling air to escape the proper path and I had a 5 blade fan. One of the things I did was to remove the alternator/fan and notice that the engine cooling fins were coated with oil/dirt. It took a fair amount of diesel sprayed in there to loosen the grease followed by steam cleaning to remove the loosened gunk. That dropped the temps another 20 degrees. It ran much cooler after proper timing, proper fuel mix, tightened air hoses, engine clean from above and 11 blade fan. Then I got the trombone cooler which dropped the temps some more. I seldom go over 210 these days. If you don't have a trombone cooler I have an extra.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
What Flat6pac said. The dizzy hold down nut should be about the middle of the adjustment space.
How hot is too hot? |
Installed at Z-1 top dead center
this is where the dizzy needs to be for 5 degrees after z-1 @ 900 rpm |
gets up to 210 and keeps heading for 250 so I shut it down this is after only running 20 minutes or less
just ran it again and after 20 minutes over 210 on the gauge but I used infrared thermometer down into oil tank and oil is 140 degrees??????
76 911S Targa
Those hand held point and shoot thermometers are really helpful. You may have a mismatch between the temperature sender and the dash mounted temperature gauge, giving you a false reading.
Rick,
Your picture shows the vacuum line still attached. It's 5 deg ATDC with the vacuum line disconnected (and plugged) at idle, and 32 to 38 deg BTDC at 6,000 RPM. With the vacuum line attached, you're probably closer to 10 deg ATDC at idle. Checking the more important 6,000 RPM timing would help show if there is an issue.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 07-21-2019 at 07:07 PM.. |
check your engine thermostat in the triangle of death, if it not working it will keep the oil in the engine and not release enough oil to the tank . Just an idea
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
I would rather be driving
Is your engine mounted oil cooler nice and clean? Any crud buildup will greatly reduce the effectiveness of it.
I would also check the tops of your cylinders and heads. You can check it all by pulling heater ducts on front of engine by fan. The oil cooler will have a gray cover on it. a few bolts and it lifts off. Its much easier done with partial engine drop.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
The vacuum line is disconnected at timing.and not needed to set timing.
Setting time at idle should be before TDC, 5 degrees +/- Vacuum line is a retard for ignition and should ONLY have vacuum at idle How does it run with vacuum hose plugged? Bruce |
