CJ CJ is offline
CJ's Avatar
340 Ft Lbs Torque On Stub Axle
I have done the search and can't determine whether a quality high end 1/2" impact wrench will get the stub axle nut off of an 87' Carerra. Has anyone successfully done this? Can someone confirm the nut size at 32mm. If this fails, i will buck up and get a 3/4" drive socket, a gigantic breaker bar and drop it off the jack stands.
Chris Johnson
87' 3.4 Carrera
73' 911t restoration project
Old 03-24-2003, 12:08 PM
I don't believe the 1/2" will do it. I used a 1" breaker with a 4" steel pipe to get mine off. A 3/4 would probably work; I used the 1" cause I got the use of it free from work. I can't remember the nut size, someone will chime in soon with the info tho.
Argo
88 Targa
Old 03-24-2003, 12:14 PM
Don Plumley's Avatar
I can't say if an impact wrench would do it, though I bet that's how the pro's do it. How many ft-lbs of torque does your impact wrench deliver?
Anyway, yes it is 32mm and yes, you need at least 3/4" drive hand tools. I bent a 1/2 drive Craftsman tool (thank goodness for the warranty). Bought a cheap 3/4" drive set from Harbor Fright and it worked great - with three feet of 1" cheater pipe.
If you were closer you would be welcome to borrow my set (offer open to all SoCal Pelicans).
Don
Don Plumley
M235i
Old 03-24-2003, 12:53 PM
Super Moderator
cstreit's Avatar
I thought those were 240 ft/lbs... Or is that only on SC's?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-24-2003, 12:59 PM
CJ CJ is offline
CJ's Avatar
Wrench says it delivers 450 ft lbs or so.
Chris Johnson
87' 3.4 Carrera
Old 03-24-2003, 01:00 PM
Yeah, the deciding factor would be the rating of the wrench, mine goes 25-250, so I'm sure I would ruin it. I think you need something bigger. Of course putting it back with the right torque could be ugly too.
Old 03-24-2003, 01:06 PM
CJ CJ is offline
CJ's Avatar
Putting it back to the right torque should be easy. from what I understand, 170 lbs (me), at two feet out on a breaker bar equals 340 foot Lbs of torque.
As far as I can tell, the stub axles on the 87 Carrera are 340 lbs
SC's I believe are different all together.
Chris Johnson
87' 3.4 Carrera
Old 03-24-2003, 01:12 PM
Super Moderator
cstreit's Avatar
Phew... Just replaced one of mine and i went to double check it too be sure...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 03-24-2003, 01:13 PM
Irrationally exuberant
ChrisBennet's Avatar
I've removed them with my 1/2" impact wrench. My Ingersol Rand 2131 is rated at 600+ft in reverse. I've since been told that it is bad for the wheel bearings to use an impact wrench to remove the axle nut. When I install them I get a helper to keep the socket pushed on the nut (with their foot) while I step on the wrench.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-24-2003, 01:36 PM
Good point Chris - when I tightened mine I supported the socket/extension with a jack stand as close to the wheel/nut as I could get it.
Argo
88 Targa
Old 03-24-2003, 01:44 PM
