Harpo's Avatar
Turbo tie rod install
I have a 3mm gap between my tack and my turbo tierods. Is this normal? I hope not. Can I install a washer/spacer?
Old 07-20-2019, 06:57 AM
Location: behind the redwood curtain, (humboldt county) california
Washer = rack stop, but is also a spacer
The kit should come with the two thick washers. If you don't use them, the tie rod joint will hit and damage the track end seal and possibly do internal damage to the pinion or the puck.
When tightening the tie rod ends, use a wrench to counter-hold one tie rod, while tightening the opposite end. This will prevent damage to the pinion or puck.
Chris
Old 07-20-2019, 07:19 AM
Mark Salvetti's Avatar
It’s discussed in this how-to article. https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/59-Turbo_Tie_Rod_Kit/59-Turbo_Tie_Rod_Kit.htm
Mark
1979 911SC Targa
Old 07-20-2019, 07:48 AM
Harpo's Avatar
Thanks, could not find the ones that hopefully came with my kit , but the hardware store had some good replacements
Old 07-20-2019, 08:24 AM
Harpo's Avatar
How far does the boot go inboard? It seems like the outboard (small end) of the boot should be on top of the end piece on the tie rod. Does anyone have any photos to show how they installed their turbo tie rod boots?
Old 07-20-2019, 10:31 AM
Dr J's Avatar
I have a kit I haven't installed yet. Seeing the comments above, I measured the washers for you and found that they are about 1-3/4" diameter. They are definitely bigger than the end piece. Yours seem too small.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 07-20-2019, 11:42 AM
Harpo's Avatar
If the only purpose of the washer is a spacer does the OD matter?
Old 07-20-2019, 01:00 PM
The washer is a rack stop
The washer comes up against the end of the rack casting, stopping the rack from traveling any further.
If you rotate the pinion, you will see that the inner Tie rod end goes into the rack and hits the end seal/rack bearing. You need the washer to Stop the tie rod end from doing this.
chris
Old 07-21-2019, 07:42 AM
Registered Minimalist
75 911s's Avatar
The inboard part of the boot extends onto the lip of the rack casting. Should be an obvious depressed lip there for the boot and boot ring to fit onto. It looks like you have the right turbo tie rod boots, they are longer than the non turbo tie rod boots fyi.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 07-21-2019, 07:52 AM
Harpo's Avatar
Sorry, I meant to ask about how the outboard end of the tie rod to boot arrangement.
Thanks everyone
Old 07-21-2019, 08:23 AM
Harpo's Avatar
Does the boot need to be pushed further inboard so it is flush with the disc on the tierod
Old 07-21-2019, 08:27 AM
75 911s's Avatar
Actually I'm not sure. it's been a while since I've done the install. This is how I had mine setup. If I recall, I didn't use the wire retaining rings on the outboard discs because the boot was a tight fit and when it set down in the lip, it was flush on the end. Not sure if I'm right here.
Old 07-21-2019, 08:55 AM
Harpo's Avatar
Perfect, just what I was looking for. Thank you
Old 07-21-2019, 09:31 AM
Boot retention
The boot snaps onto the rubber disc on the tie rod. If you are a bit anal, like me and want to make sure it stays there, you could use a tie wrap on the boot to secure it to the disc.
BUT, it needs to be able to rotate, so when the tie rod is turned to set the toe, the rod can rotate, relative to the boot, or you are going to posssibly damage the boot.
Isn't experience a wonderful teacher? Never mind about what people say about smart people...
chris
Old 07-21-2019, 02:14 PM
No need for a tie wrap on the outboard end of the boot. Once it is snapped onto place on the outside of the rubber disc on the tie rod it should stay in place all on its own.
As for the washer. The previous post are correct, you need the large diameter wash as it functions as a steering stop to limit rack travel. Without it you are putting your rack at risk. The washers are inexpensive enough that it is worth buying replacements if you can't find the ones that came with the kit.
Edit: Washer part number 930 347 313 02
Old 07-22-2019, 10:54 AM
Harpo's Avatar
I ordered a tire rub washer which will serve both purposes
Old 07-22-2019, 04:13 PM
