Engine shutting off
Here's the problem: when I start the car from cold, it first revs at about 1400, then drops to about 800 for a bit before finally settling at just under 1000 (as it should do). When it's cold outside (well relatively speaking - this is Bay Area), however, it sometimes shuts off. The problem only occurs if the revs 'drop' (when changing gears, for instance) from 2000 or above. When I let the revs decrease slowly, letting go of the accelerator gradually, it doesn't happen. What could it be?
Cheers
Axel.
1973.5 911T Targa (RS upgraded engine)
1996 VW Passat Wagon (yawn...)
Old 03-24-2003, 04:13 PM
