COA Questions
So, I imported what I thought was a 2.2 911t when I moved back from the states. Its been 3 years and finally getting around to recommissioning and registering..
My COA says it is a 1970 911t Coupe. Does this mean it is a 2.0 or a 2.2?
I do not know how to decode my engine number 6107187?
Also, it says it had chrome whole disk wheels 5.5j x 15 but now it has 14" fuchs??? What are "Whole disk wheels"?
Old 07-18-2019, 11:47 AM
The engine # is a 1970 model. See attached. What size that is, I have no clue.
Hope this helps.
From the PET. Get here:
Porsche Elektronischer Teilekatalog - Porsche Parts Manual
http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
Who, What, When, Where, Why and How.
Old 07-18-2019, 01:23 PM
proporsche's Avatar
your 911 is 1970 911T with 2,0 engine...
Ivan
also look for the number on the case..like 911/20
1985 911 with original 502 191 miles...808 198 km
Old 07-18-2019, 02:07 PM
Rescuer of old cars
Arne2's Avatar
1970 and 1971 were 2.2, 2.0 went through 1969.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 07-18-2019, 03:06 PM
I'm confused!!
Old 07-19-2019, 12:09 AM
proporsche's Avatar
Arne2 you are correct....i`m wrong....
Dpette ...it is after all 2,2...........
Old 07-19-2019, 12:18 AM
YES!!!! Thankyou.
So does anyone what wheels would be "chrome whole disk wheels 5.5j x 15"??
Old 07-19-2019, 12:22 AM
proporsche's Avatar
It looks like there were 3 options
Old 07-19-2019, 12:44 AM
racer's Avatar
1) Whole disk wheels = Steel wheels. Some had a chromed finish as well.
2) 1970 911t had a 2.2l motor. All 911's had a 2.2l motor starting in 1970.
The 1970 914/6 used the "old" T motor -2.0l displacement. A 911 with the same engine in the same year? heresy!
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-19-2019, 06:35 AM
Awesome thanks. Interesting that a one owner car has a set of 14" such on it when they purchased it with steel wheels. I guess I could sell the fuch's and put steels back on!
Old 07-19-2019, 12:24 PM
Rescuer of old cars
Arne2's Avatar
There are far more early 911s with Fuchs now than were ever built that way by the factory.
2018 718 Cayman 2.0
Old 07-19-2019, 01:19 PM
makes sense, I guess they are the quintessential porsche wheels
Old 07-20-2019, 11:08 AM
racer's Avatar
Also an easy swap by a dealer. Remember, a 911T was a price leader of sorts, so they could be find relatively light on options - 4 spd, steel wheels. A base 911T as only a couple hundred dollars more than a 914/6.
My dad's 914/6 came with steelies.. He had the dealer swap on 14" Fuchs (recall at the time, 14" was quite common size, 15" was a almost a premium size).
Past:
Old 07-22-2019, 05:39 AM
so, does anyone know what size tyres would be fitted to a 1970 14" comfort package? I am trying to get the right tyres but not sure which size to buy
Old 07-24-2019, 03:50 AM
racer's Avatar
They were likely 185/14. Back then, the default was an 80 series profile. You might find a 185/70-14 which is only slightly smaller sidewall.
I run 195/60 14 as there are one or two performance tires still available in that size. After that, at least in the US, you get less impressive touring/all season tires for your selection.
See the last post here is an old thread about the same topic:
What Size Tires on 14 Fuch
Past:
Old 07-24-2019, 04:53 AM
found a load of 185/80 14 yes in the UK. No Pirellis but just about every other make!
Old 07-24-2019, 01:14 PM
Check the classic Pirelli CN36 sizes - try Stoddard.
1971 914- original owner
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 07-24-2019, 03:28 PM
Nope, seems Pirelli do not make the CN36 in the right size
Old 07-25-2019, 10:22 AM
racer's Avatar
Michelin still makes some.. or at least Coker tire makes them using old Michelin molds.
A 205/70-14 would certainly fill up the fender wells better than most others.
https://www.cokertire.com/tires.html?brand_item=955&p=4&tire_rim_diameter=2050
Past:
Old 07-25-2019, 11:30 AM
