Spoke with the shop and thanks about the oil dye thing as will look into using that with more leakage or flow he recommends...
Ivan my friend this is a 1987 per my sig below, so believe that bulletin may apply? He said he hadn't seen that on many in the past. They also mentioned they couldn't do the full engine and trans cleaning as they don't have that capability at their facility to collect the waste and runoff. The shop also said that they could do the pulley seal with motor in the car. They suggest bringing the car in to determine the leak now that it's clean as soon as possible this week which I'll do and report back too. |
so the engine was out,you do these job in the same time while the engine is out....for you bulletin from 1985 i have not seen any leaks from the oil cooler side plug.Because there is no plug there any longer.....they just wanted to cover their butt with the bulletin.... Ivan |
| All times are GMT -8. The time now is 01:00 PM. |
