Name that oilleak
Looking for group help on identifying the leak in the photos below -
I'm getting the engine steam cleaned tomorrow and will also post photos after.... ![]() ![]() ![]()
1987 Porsche 911 Carrera - Lagoon Green |
You have flywheel seal leaking ,engine top leaking, at least this oil return tubes has marks of oil leak, if the engine looks like this i would recommend to check the case bolts to see if any of them are broken.To do this you need to remove the valve covers.Also front inter.shaft gasket and front pulley seal is most likely leaking..This 911 is in CA?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Time for a refresh. I wouldn't drive that car, possible fire hazard.
Perpetual Reassembler
My 3.0 looked exactly like that. It had the top breather tube leak, the porosity behind the engine mounted oil cooler leak, and a gearbox shifter seal leak.
What does your gearbox look like?
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
Mine wasn't as severe and that's the only issue I had as well on my 3.2
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle Instagram: @pdklol |
Thanks for all the input guys, the motor was dropped as the clutch was recently done and they replaced these -
Oil pressure switch Thermostat oil ring Breather hoses (both) Flywheel seal There was a minor drip on the floor in the garage before but now leaks(s) have increased. Heading out to get the steam cleaning done shortly and will snap more photos of the gearbox prior to cleaning if I can too. @Ivan yes in San Diego, CA
Photos after first pass of cleaning -
How is the o-rings are exposed on the oil return tubes. Sorry if that's a dumb question as my tubes are still 1 piece.
Walt 82SC 3.0 81SC 3.6 |
I think that is normal as two piece so they must have been replaced at some point.
Read this - https://www.pelicanparts.com/techarticles/911_oil_return_tube/911_oil_return_tube.htm
Hard to see from the picture, but they are most likely the circlips that keep the tubes from pulling out, but the picture make them look like o-rings.
Rutager West 1977 911S Targa Chocolate Brown |
Registered Minimalist
Yes those are the circlips for the two piece oil return tubes.
I see what looks like to be a fresh drip coming off the oil return tubes. As they are already two piece replacements, I would start there with new o rings and lube on each end. Once the circlips are placed outside the groove using a circlip spreading tool, you can carefully attach a hose clamp to one end of the oil return tube and use an angled pry bar for leverage to push the ends out. Alternatively, you can see if maybe the mechanic pulled on one of these tubes and dislodged it. Push the ends in and make sure they all look the same.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Yeah that’s actually Simple Green that he sprayed as these photos are cleaning in process. I’ll post some others later if I see a leak surfacing now that it’s clean.
Still here
calidyde..it is strange if the clutch job was done and top resealed ,how come they did not clean the engine ..that is basic care for customer....and his 911
Ivan let`s see more picks close ups
agreed...i'd go back to the shop and show them the before and after. something's not right and that's a substantial leak.
2001 996TT 1984 Carrera |
Agree with both of you as also thought it was odd not to have cleaned the engine and transmission while out
![]() Still not satisfied that this isn’t cleaner as I may scrub off some of the baked on stuff with brake cleaner. It’s still not a smoking gun to the exact leak either... Here are a couple of photos close up and it looks like the service bulletin that I found in this post - Is this leak from the oil cooler ![]() ![]() ![]()
Here’s some more including the other leak which looks like the pulley seal.
![]() Closeup of pipe area
the oil leak you are pointing to at the cooler was actually eliminated on later models. Is your`s 1988?
Use the JB weld as you can see the procedure in the other link...on your pics circle the oil it is too clean to see the new oil... Ivan still i do not get -the shop had your engine out and they did not do the front pulley seal?i wonder now if they did the engine top..correctly
