-   -   Engine won't start (http://forums.pelicanparts.com/porsche-911-technical-forum/103600-engine-wont-start.html)
bigdaddy 03-24-2003 09:33 PM
Engine won't start
88 3.2 Has been running fine until yesterday, turns over but will not fire up. wait 2 hours fires right up runs great, turn it off, restart won't start, wait 5 minutes starts up. Now it won't start at all.
Thanks for any help, car stuck in a parking lot.
steve egger
bigdaddy@maui.net
Tim Walsh 03-24-2003 09:35 PM
first thing to check is for spark and fuel and work from there.
bigdaddy 03-25-2003 10:18 AM
Checking for spark is easy, any advise on how to check for fuel flow?
thanks for the quick response.
bigdaddy
makaio 03-25-2003 11:23 AM
How old is your DME relay? Do you have a spare? I would try swaping in a known good one and see if that cures your no start.
bigdaddy 03-26-2003 12:02 AM
This is getting fun, what is a DME relay and where is it?
makaio 03-26-2003 08:16 AM
It's located under the drivers seat, it plugs into the DME. I don't know exactly what it does, but I know if it's bad it won't start. Jerry Woods told a story of one that had a problem, and would only allow intermitant starting, that's why I suggest that. About $30 from Pelican.
If you don't have it already, I would suggest getting the Bentley repair manual. And you should always carry a spare dme relay.
bigdaddy 03-26-2003 10:51 AM
Matt, thanks alot I'm going to call pellican right now.
steve
bigdaddy 03-31-2003 01:04 AM
Matt, Thanks for your help. Installed a new DME and it started right up.
The Bentley Manual was very helpful.
Steve Egger
88 911 Cab
97 Boxster
