Unhappy Engine won't start
88 3.2 Has been running fine until yesterday, turns over but will not fire up. wait 2 hours fires right up runs great, turn it off, restart won't start, wait 5 minutes starts up. Now it won't start at all.
Thanks for any help, car stuck in a parking lot.
steve egger
bigdaddy@maui.net
Old 03-24-2003, 09:33 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
first thing to check is for spark and fuel and work from there.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-24-2003, 09:35 PM
Checking for spark is easy, any advise on how to check for fuel flow?
thanks for the quick response.
bigdaddy
Old 03-25-2003, 10:18 AM
makaio's Avatar
How old is your DME relay? Do you have a spare? I would try swaping in a known good one and see if that cures your no start.
Old 03-25-2003, 11:23 AM
This is getting fun, what is a DME relay and where is it?
Old 03-26-2003, 12:02 AM
makaio's Avatar
It's located under the drivers seat, it plugs into the DME. I don't know exactly what it does, but I know if it's bad it won't start. Jerry Woods told a story of one that had a problem, and would only allow intermitant starting, that's why I suggest that. About $30 from Pelican.
If you don't have it already, I would suggest getting the Bentley repair manual. And you should always carry a spare dme relay.
Old 03-26-2003, 08:16 AM
Matt, thanks alot I'm going to call pellican right now.
steve
Old 03-26-2003, 10:51 AM
Matt, Thanks for your help. Installed a new DME and it started right up.
The Bentley Manual was very helpful.
Steve Egger
88 911 Cab
97 Boxster
Old 03-31-2003, 01:04 AM
