Dead clock --- any fix?
Clock went dead. Checked voltage and wires are good. Any typical fix for this? (Has no access through back side.)
Ladies and Gentlemen sit back and enjoy the ride . . .
Karl is about to invent a new 911 clock right before your eyes. |
You know I'm an AC junkie RN! :D Clock... not much science there. (Currently working on condenser watering idea. Curious to see how low system pressures can be brought to. High side 120'ish maybe?!)
Enjoy!
This was a trick question right? North Hollywood Speedo is the answer. They take it apart and put it back together with new capacitors. So I've heard.
There are several clock repair threads. It is a common failure, you need to replace one or two capacitors. FYI will cost you $3 and 1 hour if you can solder.
http://forums.pelicanparts.com/uploa...1564604972.jpg
^^^^^ Most likely these two guys. You will have to remove the clock, open up the back of the clock. And, replace. $1 parts. It worked for me. Gerry |
I replaced the capacitors in my clock about 5 years ago and has worked perfectly since. Don't know if this is your problem or not but not a difficult or expensive project to at least try.
http://forums.pelicanparts.com/porsche-911-technical-forum/874417-911sc-clock-repair-annotated-photos.html |
http://forums.pelicanparts.com/uploa...1564613347.JPG
Bezel takes good bit of force to bend open. There's a soldered post sticking out back side of housing that needs desoldering in order for clock mechanics to be freed from housing... and two flathead screws. http://forums.pelicanparts.com/uploa...1564613347.JPG In my clock, capacitors position with positive terminals towards clock's center. According to MHack in Walt's link... "capacitors are standard 100µF electrolytic capacitors." There is a "100" printed on butt of these caps. . |
http://forums.pelicanparts.com/uploa...1564680864.JPG
Using 100 uF 50v max. Tested in car... works. http://forums.pelicanparts.com/uploa...1564680864.JPG Cap's long wire leg = positive. Neg wire has "-" symbol against black background stripe on casing. Ground prong needs to be resoldered to housing when reassembling. ... Thanks for input guys. http://forums.pelicanparts.com/support/smileys/wat6.gif . |
I thought Radio Shack was defunct.....
this is all nice info about the clock-repairs...i have to show you one shortcut-fix i have found in one of my friends 911;-)...i bought him new clock and kept this one;-) works perfect--
Ivan http://img.pccreation.net/photos/201908020916539392.JPG http://img.pccreation.net/photos/20190802091839504.JPG |
@proporsche : added benefit = no power drain from the car battery when the car is in winter sleep !
I fixed my clock last fall and it has kept perfect time ever since. I was a bit surprised when I found a local Radio shack but they had the Caps.
That made me brave enough to fix my own odometer! |
clock repair
does anyone knows of a clock repair shop in Toronto Canada? mine stopped 3 weeks ago...
A1 Electronic Parts 196 North Queen St. Toronto, Ontario M9C 4Y1 Tel: (416) 255-0343 . |
clock
Thanks Karl, May be they can recommend a repair shop...i do not know how to solder...
Followed the thread, changed capacitors, works like a charm. Sweet fix. Thanks Guys & PP
| All times are GMT -8. The time now is 03:16 PM. |
