where to buy hinge shims?
I need some hinge shims to align my pass. side door. I couldn't find a Porsche part number and Pelicans couldn't either. The striker shims are listed but nothing for the door hinge side. Are the shims available anywhere or is it something I'll have to make myself? Thanks for any info.
Old 02-23-2005, 05:19 PM
abit off center
cgarr's Avatar
I think I had some on my 69, they were alum but I dont remember if I made them or if they were there? Anyhow most adjustment (gap) is done by bending the inner door where the hinge attaches, I used a large shot filled hammer and wack on it, if you need to go the other way there is a tool you can make to stretch it back out. Adjustment for up and down and in and out should be with the 3 bolt holes, as I remember? its been a few years and many beers since. Make sure your hinge pins have new bushings in them and not loose or your just fighting a loosing battle and it will never be rite. I did not end up using my shims, they really never worked right for me.
Craig
Old 02-23-2005, 05:50 PM
I had read where some members found brass or aluminum shims behind the door hinges that were used for adjustments. Bending and whacking the inner door seems alittle extreme for me, but I suppose the factory could have done it that way. Anybody else have experience with aligning the doors?
Old 02-23-2005, 07:34 PM
Axis11's Avatar
Pelican sells this puller for moving the hinge mount area out,Door Post Puller.
pulling/bending this area with a hammer seems extreme to me also but it might work the best who knows?
I would think John Walker or Series900 might know more on this subject. maybe they will weigh in on the best way to adjust door fit. I also sent you a PM of some other options.
_Tim
1966 911 Coupe
304784
Old 02-24-2005, 09:13 AM
I would rather be driving
jpnovak's Avatar
Make your own. Its just three holes drilled in some Al flat sheet. You can buy different thicknesses to adjust them correctly. Yes, the factory used a drift to align the doors. Its common practice. Usually the hinge is bent, not the door frame.
Old 02-24-2005, 09:25 AM
I looked in my 911 restoration guide and it specifies using the bolt holes for up/down, in/out and shims and/or bending the door post depending on direction. My car has aluminum shims.
Old 02-24-2005, 10:45 AM
Thanks for all the replies. I now have more options to explore. I guess I shouldn't be surprised that the factory would hammer and bend the sheetmetal to fit. It just seems very extreme to me, but it adds to the handfitted nature of our cars.
Old 02-24-2005, 12:46 PM
MBEngineering's Avatar
HI just a note for the part No' of the shims,
hinge shim No 90153139120
striker shim 1mm 90153170323, 2mm 90153170324,
any good ???? mike
Old 02-24-2005, 02:31 PM
Mike, thanks for looking up the part. I had found those same numbers after talking to Pelicans and the dealers. They could not tell me if the 90153139120 base plate was actually a shim or the other side of the door hinge. Have you purchased this item and it is a shim?
Old 02-24-2005, 03:13 PM
HI that part No is the spacer shim for the door hinge, one size only, in ally
regards mike
Old 02-28-2005, 01:31 PM
Hi Anyone has a template for making these hinge shims, please post
Old 08-07-2019, 02:43 AM
Cars and Cappuccino
tdw28210's Avatar
FWIW, the door hinge shims I've found are hard ABS plastic. also, might want to post a WTB advert over on the Parts forum.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 08-07-2019, 03:48 AM
Brew Master
cabmandone's Avatar
I have a pile of them. PM me your address and I'll mail you some.
HOLD IT! I just looked in my shop and was only able to find one. I know I have a stack of them tied together. I'll do some looking and post back today if I find them. Gotta clean my shop up anyhow.
Reuben, I don't know how I'd get you one to south Africa reasonably but you're welcome to the one shim I found to use as a template. I have no use for it.
Nick
Old 08-07-2019, 04:59 AM
Door Shims
Hi Cabmando,
I guess it is small enough to photocopy to actual size and/or let me have the overall dimensions and spacing between the 3 holes should be good enough
Thanks for the offer
Old 08-07-2019, 09:29 AM
Send a message via ICQ to AirJose
Reuben,
These aluminum shims come in different sizes. 1.5mm and 1.0mm comes to mind. I purchased some, months ago but I am not sure if they were Stoddard or Sierra Madre (hope I am not in trouble for mentioning competitors of Pelican) The door lock uses plastic.
Jose
Old 08-07-2019, 10:57 AM
Brew Master
cabmandone's Avatar
Originally Posted by Reuben911 View Post
Hi Cabmando,
I'll throw one in the scanner and make a copy of it. If you'd like me to email the scanned doc, PM me an email address and I'll have it to you this afternoon.
Nick
Old 08-07-2019, 11:33 AM
ChieftanMews's Avatar
I just bought a bunch of new ones. If you want I can take pics with measurements? Feel free to send a PM if you want!
1980 911 SC - Project
Old 08-07-2019, 12:05 PM
