Pagid yellow pads?
Can anyone ID these pads for which calipers? Looks like a turbo, but not sure. Also, what applications are yellow for? I already have orange for track useage. Thanks.
Old 03-23-2003, 12:14 PM
Bill Verburg's Avatar
Yellow (RS 9): This is a classic long endurance compound with superior pad and disc wear up to 450 degrees Celsius, (842 degrees Fahrenheit). It has a medium friction value suitable for booster equipped cars with good dimensioned braking systems and reasonable cooling. This compound is also an excellent solution for over braking (locking up). Used together with rear axles using RS 4-2, RS 4-2-1, or RS 4-4 on the front. RS9 can also be used as a sport compound for street applications.
Bill Verburg
Old 03-23-2003, 01:41 PM
Bill, I am impressed!
Old 03-23-2003, 01:47 PM
Check these dimensions against yours this is a 964 pad(other aps as well)
Bill Verburg
Old 03-23-2003, 02:01 PM
Typical Ebay item, Auction is almost over and no response from seller on which caliper it fits. Are you saying this is a 964 pad? I am looking for an 80's turbo pad. Thanks Bill.
Old 03-23-2003, 02:18 PM
The same pad is used on 78-89 930
Just for completeness, here is a 911 A
and a 993/S4 front
Bill Verburg
Old 03-23-2003, 02:24 PM
Almost forgot Big Red
Bill Verburg
Old 03-23-2003, 02:48 PM
AES AES is offline
Hey Bill, how about an M and Boxster for comparison? TIA
Old 03-25-2003, 03:59 AM
Super Moderator
cstreit's Avatar
I use the same pad with 944T/964 calipers and on my 82 930...
THe yellows tend to be particularly hard on my rotors. I also use the orange for the track... However we did an entire 6 hour endurance race on ONE set of PAGID yellows in a lightweight 911 a few years back... (and one set of Kumho VictoRacers I might add)
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-25-2003, 05:48 AM
Boxster S front
Boxster front
M 911 Rear
Bill Verburg
Old 03-25-2003, 01:25 PM
