Ducktail and Rear A/C Condenser?
Can a fiberglass/carbon fiber ducktail be used with the rear A/C condenser?
I have read conflicting descriptions. Some indicate that the non-metal base ducktails (fiberglass and carbon fiber) are not designed to include the mounting of the rear A/C condenser. Is this true?
Thanks.
Lawrence
Old 11-24-2010, 10:59 AM
6 cylinder symphony
I don't think that's true. If you look at how the condenser is mounted, most of the load is supposed to be at the hinges. The center support is just extra.
When I mount my duck, I'm not going to remove my a/c condenser.
Ken
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 11-24-2010, 12:32 PM
cattledog's Avatar
The condenser fits between the hinges. It is simple enough to attach further bracing to support the condenser either to the fiberglass or the hinge brackets. I've been running this config for some time, no issues.
'83 SC coupe Quartz grey metallic(gone)
'58 spdstr 83677 1600N
'94 968 Coupe 6-spd
Old 11-24-2010, 12:34 PM
My condenser was supported by the passenger side hinge and a center support from a rib on the stock decklid. When I fitted a fiberglass ducktail it didn't have a center rib so I couldn't use the center support. I fabbed up a support for the drivers side hinge with aluminum angle form Home Depot. It's worked fine for 2 years.
John
'86 911 Coupe
Old 11-25-2010, 11:09 AM
80-911SC's Avatar
if you order from TRE he has an option that puts another support or something into it ...
Old 11-25-2010, 04:02 PM
JClanin
jclanin's Avatar
Send a message via Skype™ to jclanin
duck tail - AC condenser support
Hi there - any way you could share a pic of your fabrication on the drivers side hinge? I want to do the same thing and would love to see how you approached it.
thanks,
Jim
Old 08-07-2019, 10:13 AM
Its more than do-able, here is what I did with mine...it is a RetroAire condenser....
Hope this helps...
Dennis
Old 08-07-2019, 11:15 AM
