1986 930 brake sensor diagnosis
new pads and sensors. The brake sensor dash light does not turn off. what is the best way to diagnose the problem? Thank you
Old 07-19-2020, 09:58 AM
Bill Verburg's Avatar
The lamp comes on for either of 2 reasons
1) ground contact-usually due to worn pads
2) open any where in the circuit
Bill Verburg
Old 07-19-2020, 10:45 AM
proporsche's Avatar
albi.Remove the clock ..then with the ignition on reach inside and unplug the warning light plug or...put the key on and remove the ground from your battery for couple of seconds-key on lights on dash on..this will reset the warning light..then report..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-19-2020, 01:05 PM
