-   -   15" A032R tire pressures (http://forums.pelicanparts.com/porsche-911-technical-forum/103689-15-a032r-tire-pressures.html)
don911 03-25-2003 12:26 PM
First DE event coming up this weekend. It will be my first time with 15" A032R tires.
Anyone care to share their pressures for these tires?
Jack Olsen 03-25-2003 12:47 PM
I'll quote the fast guy on the board:
Originally posted by Randy Wells
For AO32Rs and the track on a 911, start at 23 front and 25 rear. Bleed when hot to 25 front and 29 rear. I know this seems low, but it works - these tires will get greasy when pressures rise above 30psi.
Dantilla 03-25-2003 04:10 PM
What about Hoosiers?
dad911 03-25-2003 04:39 PM
I have found Hoosiers like 41 lbs hot. Start at 35, get them hot, pull in pit & bleed down to 41. If you start at 35, and can't get to 41, drive harder.
cstreit 03-25-2003 04:45 PM
Hoosiers are slightly dependant on car weight. For a lightweight car I would actually end up at 38-39 hot (front and rear). Keep in mind that if they hit 43-44 traction will dissapear at an exponential rate for every pound thereafter.
PCA7GGR 03-25-2003 06:13 PM
I run Yoko 032s and concur with Jack's recommendation.
don911 03-25-2003 06:17 PM
Thanks for the replies! Hopefully the A032s will be in tomorrow. I also have a set of hoosiers that came with the wheels so now I set for those tires as well.:)
SteveF_911 03-25-2003 07:20 PM
On the Track I run 32PSI cold on the back tires and 28PSI cold on the front.
After the first run I check how much of the tread show wear and adjust it up or down.
A lot depends on track temperature and track type.
cstreit 03-25-2003 07:57 PM
THe low tech mthod is the chalk test.
Draw a line of chalk across the tire to the sidewalls. If it'd worn more at the edges, increase pressure 2 psi, if worn more at the center, decrease 2 psi. Make pressure changes 2 psi at a time (according the old p-car guy that got me started).
...or go the hi-tech method and buy a tire temp guage...
