15" A032R tire pressures
First DE event coming up this weekend. It will be my first time with 15" A032R tires.
Anyone care to share their pressures for these tires?
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Administrator
I'll quote the fast guy on the board:
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Non Compos Mentis
What about Hoosiers?
Platinum Member
I have found Hoosiers like 41 lbs hot. Start at 35, get them hot, pull in pit & bleed down to 41. If you start at 35, and can't get to 41, drive harder.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Super Moderator
Hoosiers are slightly dependant on car weight. For a lightweight car I would actually end up at 38-39 hot (front and rear). Keep in mind that if they hit 43-44 traction will dissapear at an exponential rate for every pound thereafter.
I run Yoko 032s and concur with Jack's recommendation.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Thanks for the replies! Hopefully the A032s will be in tomorrow. I also have a set of hoosiers that came with the wheels so now I set for those tires as well.
On the Track I run 32PSI cold on the back tires and 28PSI cold on the front.
After the first run I check how much of the tread show wear and adjust it up or down. A lot depends on track temperature and track type.
66 911 with S engine 2008 Westfield XTR2 |
Super Moderator
THe low tech mthod is the chalk test.
Draw a line of chalk across the tire to the sidewalls. If it'd worn more at the edges, increase pressure 2 psi, if worn more at the center, decrease 2 psi. Make pressure changes 2 psi at a time (according the old p-car guy that got me started). ...or go the hi-tech method and buy a tire temp guage...
