bosch twin plug rotor?
Hi
Still on the search for a bosch twin plug rotor, new or used. Tried German Auto in St Louis already |
Super Moderator
BritWrench had one at one point, or at least knew of the whereabouts...
I think Steve Weiner might have one or two, but understandably is guarding them closely. You know, I think THIS would be a much better oportunity for a co-op agreement ala Waynes idea with the GT flares from a few days ago... If you could produce these in a decent quantity, they'd most certainly sell...
Super Moderator
Okay so here's Chris' crazy idea... ...someone tell me why you couldn't get a really high output coil and use a Y harness off each plug on a single distributor to make a twin plug one...
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 03-25-2003 at 03:39 PM.. |
Andial says no way jose- they are working on a company that says 1-2 years before they have them!
btw- Bosch lost the molds to the originals when they were in the moving process |
Author of "101 Projects"
Andial had one for one of their distributors - they sent me a pic of it a few months ago for the new book...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
not available at any price from them now
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Steve / rennsport doesn't have any and yes the caps are in the $600-800 range now.
There is probably a difference between the magnetti and the bosch rotors dimensionally. the caps should be interchangeable. We found a magnetti rotor and will report back if it can be converted for use on the bosch shaft
OK.. I was at the Parts Obsolete Camp Out last spring and hung with a shop owner for a few days from Glendale/Burbank.. a small 356/911shop.. if you can't find the name.. I'll start digging.. he has many of these crazy parts..
Dave, I think your on the right track ...
I think I heard someone converting an old Maserati twin plug 6 distribuator and cap ... unfortunatly those are just is rare... but Cheers, Chuck |
I left a message for the burbank shop- will post results
thanks! |
Another shot in the dark here; you might check with the Alfa guys. I restored a '64 TZ (many years back) that I'm fairly certain runs a similar twin plug rotor (although the cap differs due to the number of cylinders). Many of the factory race cars ran twin plug heads; e.g., the GTA's, TZ-1, TZ-2's, etc.
You might give Phil Reilly and Co. a call. (415) 924-9022. Cheers, Chris |
Is this what you're looking for?
Paul
My ignition is retarded. |
Oops, better pic.
yes! i want... I want.... pant, pant,pant!
The good news is; you're welcome to it.
The bad news is, what i am pointing to in this pic is a hairline crack. If you want i can ship it out there and you can have a look. If you want it, fine, if not ship it back. Paul
Super Moderator
Ummm.... You wouldn't happen to have TWO?
My thought was to use a standard dizzy as a trigger for somekind of dual coil setup. Mind you I'm no electrical engineer, but it sure seems a dizzy working with a low-power discharge could provide a signal to trigger a pair of ignition circuits. Any automotive, EE types care to comment .... ?
Greg |
