Unhappy Relay advice
76 911 targa imported from Germany 1980 by US soldier.
Current milage ~75,000
Fuel pump not getting power,, cannot here it.
Plan is to replace all 3 relays 2 black and 1 red.
Question : should I disconnect the battery while I change out the Relays?
Question 2: any simple test I can try to verify fuel pump is bad?
Old 08-17-2019, 08:37 AM
ROW '78 911 Targa
timmy2's Avatar
Does your horn work?
If so, Just swap all other relays into it one at a time to test.
No need to disconnect battery to swap them.
Simple test for pump is to remove air filter cover, then with ignition in run position, lift the air metering plate from below for just a few seconds. You should hear the pump and possibly the injectors will “squeal “ as they load up with fuel.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-17-2019, 08:49 AM
ROW '78 911 Targa
timmy2's Avatar
New members should post a picture of their car..
Dennis
Old 08-17-2019, 08:51 AM
proporsche's Avatar
As Dennis said or, another simple test with the ignition key off cross -witha little jumper fuse number 6 (direction from the windshield) with fuse 3 you should be able to hear the fuel pump..
Ivan
then let us know
1985 911 with original 502 191 miles...808 198 km
Old 08-17-2019, 08:53 AM
relays thanks
thanks for all the help.
i did find one bad relay using the swap approach, will try some of the other things these coming days. this was a wedding weekend for a family member so have not had much spare time.
by the way , the reason my 76 911 only has 75,000 miles is i found jout many years ago they don't break as often if the stay in the garage.
so thanks again
Old 08-18-2019, 09:39 AM
thanks,, i will keep you posted...
Old 08-18-2019, 09:40 AM
Ivan
then let us know
Thanks for helping.
When you say jump 3 and 6
Do you mean jump from top of fuse 6 to the bottom of fuse 3?
I am slowly doing this since it's hot here and my garage is not cooled.
The relay was bad and #1 fuse was blown. Replaced both but still can't hear pump.
I might have blown the fuse screwing with the relays.
Old 08-21-2019, 06:05 PM
New-ish 911SC Targa Owner
pampadori's Avatar
Are you expecting to hear it prime before it starts from simply turning the key to "on"?
I seem to recall that CIS cars don't prime like that. That metering plate safety switch mentioned earlier needs to be raised by the vacuum of the engine cranking.
If you need a hand, I'm local to you and don't mind helping folks.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 08-21-2019, 07:29 PM
My how things are changing rapidly. But I am not holding my breath.
Could my 76 911 targa have been a Belgium police car
I purchased my car in 1980 from a US army officer who bought it back from Belgium to Ft Lee Virginia.
I was just doing Google searches to identify the exact location of the fuel pump. So I come across a wiki search that talks about a very small production run of 911 targas for the Belgium police. Now here's the real kicker, it has a sirene installed under the dash. I did not know what it was for many years but at some point a few years back I happened to find a button on bottom of dash and pushed it. Low and behold it turned the siren on.
I always just assumed it was part of a security system until I ran across the wiki article.
So does anyone know how /where I could validate my suspicion.?
Old Today, 10:05 PM
Old 08-21-2019, 09:32 PM
Yes. Thank you very much. I will keep that in mind. I am actually in prince George county just outside Hopewell. About 3 - 4 miles. It's unfortunate I can't drive it to a shop. I have spent most of of the last 12 months in and out of mcv with major health issues. So except for starting every 4-6 weeks it has not been out of the garage.
Fortunately I am finally feeling well enough to to address the problem with fuel pump. And in the process discovered it could be 1 of 20 police cars built for the Belgium government in 1976. Although I seriously doubt it is one but it does have a factory siren.
But thanks and I will keep in touch with you.
Henry Wilson
Old 08-21-2019, 09:45 PM
proporsche's Avatar
Cinci ..here
Old 08-21-2019, 11:12 PM
Old Today, 10:05 PM
NO, ABSOLUTELY NOY.......
Glad this got resolved , now i ca get back to getting it running.
important info to determine :
Belgium police car had type 911/83 Engine with MFI
My 76 911 Targa has type 911/81 Engine with CSI
My 76 911 Targa has Engine SN 6362331
Old 08-23-2019, 01:15 PM
FP testing........
Cinci ..here
Ivan,
The test procedure you suggested above will not work for ‘76-‘83 CIS simply because of the FP relay in these cars. Your suggested procedure is taken from the Carrera 3.2 (Motronic) Manual. We had previous discussions of this topic not too long ago with John Walker. Remember the thread?
Tony
Old 08-24-2019, 05:54 AM
proporsche's Avatar
yes i realized Tony ,thanx..my bad ..i think i did it before;-)
Ivan
Old 08-24-2019, 08:22 AM
Check your private messages
Old 08-24-2019, 10:48 AM
Thanks for your help.
I tried the test this morning, removed the air filter, (installed my $4000 hearing aids) and i do hear a very high pitch constant buzz so it must be getting power.
Can you suggest any additional test?
The battery is on a battery tender so it is fully charged.
thanks
Old 08-24-2019, 11:38 AM
Fuel pump relay terminal test.........
Search for DKLever48’s thread about FP relay test thread in the Technical Forum.
Tony
Old 08-24-2019, 11:48 AM
