questions about starting an engine after extended storage
My engine has been layed up for about two years and I plan on putting it back in the car in about a week.
What are the proper procedures for doing so. It is carberated and I will fill the bowls up and make sure none of the seals are leaking and that they arent gummed up. I drained the fuel when I dropped the engine and layed it up. I have read or heard that some marvel mystery oil in the cylinders before start up will help the rings. Initially, I plan on cranking it over with the coil disconnected. anything else? any special advice from our mechanic types? The engine has less than 5,000 miles on it from rebuild. Thanks |
Taste a drop of the oil first.:p
use a wrench to turn it over by hand with the key off. i thought i read a post a while ago that you should not crank the engine with the coil wire off it may cause problems with the electronics.
Anything else one should do? I am putting in a 2.4 motor in my 68 911. The motor has been sitting dry for around 8 months. . Thanks.
-Alan ___________________________________ 206 AA 1968 911 Targa 2.4t |
Do a search for Marvel Mystery oil. I think I remember reading that people squirt some in the jugs before turning the engine over.
| All times are GMT -8. The time now is 12:53 AM. |
