jmz jmz is online now
jmz's Avatar
questions about starting an engine after extended storage
My engine has been layed up for about two years and I plan on putting it back in the car in about a week.
What are the proper procedures for doing so. It is carberated and I will fill the bowls up and make sure none of the seals are leaking and that they arent gummed up. I drained the fuel when I dropped the engine and layed it up. I have read or heard that some marvel mystery oil in the cylinders before start up will help the rings. Initially, I plan on cranking it over with the coil disconnected.
anything else? any special advice from our mechanic types?
The engine has less than 5,000 miles on it from rebuild.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 03-25-2003, 07:10 PM
Mark Wilson
Guest
Posts: n/a
Taste a drop of the oil first.
Old 03-25-2003, 07:13 PM
47silver's Avatar
use a wrench to turn it over by hand with the key off. i thought i read a post a while ago that you should not crank the engine with the coil wire off it may cause problems with the electronics.
1975 911S Targa
Silver Anniversary Edition
Old 03-25-2003, 08:09 PM
Anything else one should do? I am putting in a 2.4 motor in my 68 911. The motor has been sitting dry for around 8 months. . Thanks.
-Alan
206 AA
1968 911 Targa 2.4t
Old 05-19-2003, 12:18 AM
Mark Wilson
Guest
Posts: n/a
Do a search for Marvel Mystery oil. I think I remember reading that people squirt some in the jugs before turning the engine over.
Old 05-19-2003, 03:10 AM
