teal911's Avatar
fuel line pressure side
hello every one,
Today a gas leak sprung out from the banjo fitting at the fuel pump and I will need to replace the whole fuel line.
I seem to remember that a member of the forum was manufacturing some adapter hose with the fitting that would make the job a lot easier.
Does anybody know where is the thread ?
Thank you
80 SC targa Teal
78 Lancia montecarlo Teal (in Italy)
70 euro Mercedes 250 CE Blue met.
05 Lexus 470 GX White
Old 09-14-2019, 07:40 PM
Search user name BoxsterGT
Old 09-14-2019, 08:14 PM
Harpo's Avatar
Len doesn't respond to pm, only email len.Cummings at verizon.net
Old 09-15-2019, 03:57 AM
Yea, just get Len's hoses. Get both of them. While you are changing one it would be wise to change both. He has the fittings that make it lots easier.
Get a helper! I worked on my hoses for over an hour and had one part way through with a lot of trips back to front. With a helper just doing the push me pull you wiggle the hose, it is fast and fairly straight forward. Still a total pain to do with the steering rack and the transmission in the way. If can be done, and you may need to invent some new profanity to help it all happen, I invented several new words when I did mine.
Old 09-15-2019, 09:00 AM
BoxsterGT's Avatar
Porsche Crest
teal911-
Rino, you will have to send me a email address that works.
My reply to you was bounced as undeliverable.
Len
Old 09-15-2019, 03:28 PM
