Scott R's Avatar
Under dash AC vent hose source?
I've looked all over the Pelican catalog, and even in the new parts diagrams and no joy. I finished a major overhaul on my AC today, nice 40 deg vent temps on my stock SC AC system and now I need to close one more hole. There are two little vents on either side of the dash, these connect to the air box with an odd size paper hose, anyone know where I can a replacement? The left side is crumbling away needs to go, cold air on my feet is not exactly where I want it.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-26-2007, 06:01 PM
schoward's Avatar
I know this sounds crazy but i replaced the hose going to my pass side dash vent on my SC with a section of shop vaccuum replacement hose. Perfect diameter, black ribbed plastic hose, kind of rigid. actually looks somewhat factory. also had nice cold AC blowing into footwells. no more.
one end was a little too tight (end that slips on vent), used a little heat and a pipe expander and snugly slipped it on.
just a thought. I hear the factory ones are very difficult to find.
Old 08-31-2007, 06:05 PM
khamul02's Avatar
Circa 2007 bump... Does anyone know what size hose goes to the small dash vents and where to get a replacement?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 08-14-2019, 01:21 PM
aircraft Supply houses are a good source of these hoses. They are also very high quality.
Try Aircraft Spruce
Brown Aircraft supply
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-14-2019, 01:32 PM
stevie 77 930's Avatar
911 571 228 00 about $ 11.00 You can order on Pelican
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 08-14-2019, 01:38 PM
khamul02's Avatar
I ended up buying some 1.5 inch pool pump hose from lowes by the foot for a couple bucks. Worked great.
Tom Hutchinson
Old 08-16-2019, 12:14 PM
