-   -   915 advice needed (http://forums.pelicanparts.com/porsche-911-technical-forum/1037572-915-advice-needed.html)
Geronimo 08-20-2019 02:29 PM
I do freely admit that my car might be a cursed pile of @#$% ;)
WP0ZZZ 08-20-2019 03:32 PM
Originally Posted by sugarwood (Post 10564945)
No, that's not how a correct 915 works.
I have zero issues going into 2nd gear, ever.
https://www.youtube.com/watch?v=AmOwHoJlK14
Do you have any video trying to shift quickly?
Nick Triesch 08-20-2019 03:56 PM
Sure Sugerwood. Sure.
Nick Triesch 08-20-2019 04:12 PM
Will never shift like a Honda Civic. And that’s ok. It is a 915.
911pcars 08-20-2019 04:42 PM
Looks like an attempt at double clutching, but ends up rev matching, or not clearly demonstrated.
Still the best YouTube video on how to do it correctly. I guess it takes a babe to demo it correctly,
<iframe width="560" height="315" src="https://www.youtube.com/embed/NSup4MLX2GU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Sherwood
pmax 08-20-2019 04:53 PM
Here's one.
https://youtu.be/i1Xn9Tq3Beg
<iframe width="560" height="369" src="https://www.youtube.com/embed/i1Xn9Tq3Beg" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Geronimo 08-20-2019 05:14 PM
LOL, i'm sure that's the same 915 that I have...
RSTarga 08-21-2019 09:44 AM
<iframe width="560" height="315" src="https://www.youtube.com/embed/AmOwHoJlK14" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
You will if you keep resting your hand on the shifter;)
Nick Triesch 08-21-2019 10:59 AM
Same guys say their 911 does not use a drop of oil!!!!
cabmandone 08-21-2019 03:57 PM
My car shifts just like the one in the video... right up until I decide to really jump on it then... not so much. Show me a fast 1/2 shift at about 6000 rpm's then ya got something.
Geronimo '74 08-23-2019 02:59 PM
Same here, sometimes slight resistance going in to second, other times smooth.
Did notice more smooth shifts during spirited drives.
cabmandone 11-28-2019 04:04 AM
I had to revisit this thread after doing a video in preparation of removing my transmission. Here's my car under higher rpm shifting. It's good but the one I'm going to be putting in with 1/2 being refreshed will be better. I didn't include downshifts in this but 2-1 is brutal and 3-2 can get a bit sketchy from time to time. Going up through the gears is pretty good though. I could have matted it but feathered into 1 so I didn't jar the cameraman too much. Thanks to my son for a steady hand!
<iframe width="1131" height="636" src="https://www.youtube.com/embed/xHRVB5qTCeQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Locker537 11-28-2019 06:04 AM
Second gear is "tricky" in my 915 as well. It's the same for both up and downshifts and consistent across RPM.
The only time I'm particularly challenged by it, is downshifting into second on track. The extra effort requires takes more time, and will throw off my rev matching. My solution is more practice.
Hotshot 11-28-2019 06:26 AM
Can’t say how thankfully I am for this post. As a new 915 owner, you think your crazy or your cars a mess, then you read here and it’s all normal. Second sticky some times, the “ 2 stage shift “ , I know exactly what you mean!! Keeping revs up and only using 1st from a stop.
I tried once ( muscle memory from a civic ) to jam it to 3rd. That was the worst sound I’ve made in a car. Will spend next year really learning this gearbox before I think it needs a rebuild.
Locker537 11-28-2019 06:33 AM
There's really no reason to downshift into first. Don't fight it.
My 915 is very easy to shift into first prior to coming to a stop. Under 5 mph on the street.
Hotshot 11-28-2019 06:34 AM
cabmandone 11-28-2019 07:41 AM
I'd be happy if I could hit 1 at 5 mph.. I can't go into 1 unless I'm at a compete stop without it grinding. I recently drove my brother's car with a refreshed 915. It shifted the way a manual should shift. Not a modern manual but a good shifting 915. I was reluctant to go from 2-1. I was doing about 20 mph and my brother says "go ahead it'll do it". I gritted my teeth and went from two to one without any issue. That's what I want! A normal shifting transmission. Going to be installing the spare 915 my brother and I did a 1/2 refresh on a few weeks ago and then I'll be selling the one in the car during that video above.
dhanl82 11-28-2019 08:33 AM
Hello and Happy Thanksgiving,
I have a 1982 SC with a 915. The engine and and transmission have 95K miles on them and have not been rebuilt. I just replaced all the clutch/flywheel and all components and the linkage was adjusted. I have always run Swepco 201 - a little stiff when cold but fine as it warms up.
I have had the car for 5 years and at the beginning I found the 915 to be a little different, but I discovered that if I was patient with it and did not try to force it or shift as fast as I would with a modern car it worked just fine, in fact I really have come to enjoy it. I have found that if I do not rush the first to second there are no issues at all, as far as going into first, my car goes in easier while still moving a little bit rather that at a dead stop, it will however slide into first at 10-12 MPH with out and grinding, just slides in.
Anyway, just my thoughts.
Dave
911pcars 11-28-2019 09:37 AM
Originally Posted by pmax (Post 10565113)
Here's one.
That's how most enthusiasts downshift ... by rev matching..... then wonder why it gradually becomes more difficult to downshift, especially into 1st or 2nd.
Rahal rev-matches because it's the fastest way to downshift and not upset the car when re-engaging the clutch. He also has a racing budget which includes periodic maintenance and replacement of worn transmission parts (synchros). Most of us don't have that luxury, that is unless a rebuild every few years qualifies as periodic maintenance.
Learn how to double clutch as the young lady demonstrated. I suggest practicing by starting from the neutral position while coasting at speed, then practice rev matching in neutral before downshifting. Do it right and the only sign you have downshifted will be the revs. It will soon become second nature. Your synchros will love it, your transmission will last a long time and you won't fear downshifting into first if the need arises.
S
Larmo63 11-28-2019 09:54 AM
Funny how 2nd gear can be tricky at times. You think it's all the way down in second, but you know intuitively that it really isn't all the way there and it's that last little "click" that finishes the gear change.
I find it strange that Porsche couldn't get it right until the G-50.
Wait, is the G-50 perfect????
