Tool kit - what am I missing?
My '79 tool kit - what am I missing?
http://forums.pelicanparts.com/uploa...1565982724.jpg http://forums.pelicanparts.com/uploa...1565982724.jpg Thanks Jason |
Spare fuel pump relay and a fuse assortment. Otherwise, looks pretty complete.
you are missing the Klein or Hapeve pliers..like these...Pudenz fuse set and a tire gauge
Ivan http://img.pccreation.net/photos/20190817182437374.JPG |
I don't think that little Allen wrench belongs.
You are also missing a tow hook, I believe. One of these that fits in a hole on the left rear bumper: http://forums.pelicanparts.com/uploa...1566094371.jpg Mark |
Mark you are correct but this tow hook is for 930 i believe
Ivan |
Thanks to all
Jason |
Missing the LONG allen with the rubber boot on the long end plus the steel tube that goes with it.
These together are to remove the bolt that holds the battery down. |
I thought there were two types, one short that screws into a receiver somewhere (rear bumper?), and this hook-type. I thought the one pictured was for US cars, and the screw-type for ROW. Since my recently acquired tool kit is also missing a tow hook, I'd like to understand which one I need as well. Mark |
Mark |
Mark what i remember is that 930 had the hook type hole and other 911 threads under the left rear bumper molding.Remove the plug and see what do you have,i bet it is threaded...
For the color of the tag on tool kit .We did some research in French forum and here are the results... 911 carrera 3.2 from 84 to 86: red (coupe, targa or cab) 911 carrera 3.2 from 87 to 89: black (coupe, targa or cab) 930 3.3: gray 911 SC US 74 to 84: yellow |
Ivan, I took your suggestion and popped off the plug on my 1979, and found that my car needs the hook-type. There are no threads. The engine is out, so it was easy to confirm from the inside as well.
https://photos.smugmug.com/Cars/Pors...nection-X2.jpg Mark |
I think the colors are all over the map. I just bought one that is supposed to be from an SC, and it's green. On eBay there's a green one and a yellow one.
This thread shows a red one: http://forums.pelicanparts.com/porsche-911-technical-forum/946479-tool-kits-overview-74-up.html I think all these years later, it's hard to tell unless we find an original owner that still has their tag. Even then, I bet there were multiple colors used. I've never seen an explanation of what they mean. Mark |
Mark all this search was done with an original owner only...
Ivan |
Tool kit.
http://forums.pelicanparts.com/uploa...1566223939.jpg
^^^^^ Here is a picture of the tool kit that was provided during our factory delivery. When cars were delivered to the Porsche U.S.A. delivery center, there were no tool kits in the cars. However, tool kits were stocked, and, sent separately to the dealers, from the factory Porsche delivery inspection location such as Reno Nevada. Gerry |
Tool Kits.
http://forums.pelicanparts.com/porsche-911-technical-forum/1030732-tool-kit-tag-color-codes.html
http://forums.pelicanparts.com/porsche-911-technical-forum/574844-color-tag-tool-kit-what-does-mean.html ^^^^^ Here are a few links which might help. Best, Gerry PS: We had a friend who was the manager of the Reno pre-delivery inspection. (PDI). During one of our visits, we saw a large stash of tool kits. |
Tool kit.
http://forums.pelicanparts.com/uploa...1566225942.jpg
^^^^^ Our (grey tag) replacement tool kit Gerry |
Thanks Gerry. I don't doubt Ivan's info, but I think there are exceptions and no fast rule. Ivan, your results may also be different as I imagine most of your survey were non-US cars.
I always thought the explanation in one of your links made sense - the dealers had piles of kits and didn't pay a whole lot of attention to what went into each car they sold. So we're left with a fairly random data set. And then there are the bags themselves. Seems like some SCs had brown bags. Some are smooth. I bought this one, which is perforated: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1034713-original-tool-kit-911sc.html Pelican user ozbeycem seems to collect tool kits and may be the closest we have here to an authority. You can search for his Pelican posts and his eBay ads (ozbey904) to get some idea of what is correct. Mark |
so you showed me yours, i show you mine--tool kit
Ivan Yes Mark, it is all mystery those tags;-) http://img.pccreation.net/photos/201908191927552026.JPG |
| All times are GMT -8. The time now is 03:12 AM. |
