Mystery black box
Changing out master cylinder in my 78 SC and found this bakelite box tucked down near the AC ducts. Pretty sure it's not factory, no markings other than a number scratched on the front. 9 white wires go to a harness that disappears into the nether regions.
Alarm system or immobilizer installed by a PO? Anyone recognize it? It's not sealed very well and there's a bit of corrosion on the PCB so I'd prefer to just remove it if it's not doing anything useful but before I do thought I'd ask the collective wisdom first. TIA.
1978 911SC 3.0, 163K+ miles, Copper Brown Metallic |
yup get rid of it.Just follow the wires and see where they end up at the fuse box.My guess is by the fuel pump fuse..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Mystery box.
Open the white connector, and check for any start-up
issues. Based upon the number of IC's this may involve some type timing circuit. Yes, proceed to the fuse panel connections, and, the other (?) door switches(?), trunk(?) connections. Before you disconnect any of the above, document the wire colors, and the connection points. pm me as needed. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Meh, I probably wouldn't worry about it. Unless.... I was being tailed by 4 ugly Dudes that were high level drug dealers in a big Ford station wagon.
Look under the driver side dashboard. My guess is those wires pop out under the dashboard and are tied into the ignition circuit. My car had an aftermarket alarm like yours and the wires were spliced into the heavy gauge yellow wire along with a relay.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
