emac's Avatar
Help MSD street fire
Need help- installed MSD street fire as listed below car started right up but backfires bad when I press gas.
Heavy Red to top block of three fuses in rear
Heavy Blk to ground
Red to center bottom of six pin
Orange to right bottom
Black to right top
Gray to center top
Violet to left bottom
Green to top left
White is taped off
Thanks in advance
Ernie 81 SC
Old 04-26-2017, 10:15 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Ernie - I've attached a link to one of our site's DIYs on the MSD system. I hope this will help you troubleshoot.
Porsche 911/928/944 MSD Ignition System installation | 1965-1989 | Pelican Parts DIY Maitenance Article
-Dmitry
Old 04-26-2017, 10:22 AM
ROW '78 911 Targa
timmy2's Avatar
Try swapping green and violet wires.
Did you check your timing?
What did you set your rev limiter to?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-26-2017, 10:24 AM
emac's Avatar
Timmy
Timing is set to spec. did not touch it
Rev limiter is 6,200
I will try switching the wires
I did not regap the plugs yet. Set at .026
Old 04-26-2017, 10:35 AM
I believe that the Streetfire matches the factory CDI when wiring the Green wire, while the 6AL is switched.
In other words, wire the green and violet wire the way they came from the factory, not the way all of the threads here tell you to wire them, since all of those threads are about wiring up a 6AL...
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-26-2017, 12:29 PM
emac's Avatar
Dennis
Switched the wires and all is good
Thank you for you help
Ernie
Old 04-26-2017, 01:19 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by emac View Post
Timmy
Set at 0.029 factory. Easy to go to 0.035 with MSD. Secondary though.
If it backfires your O2 circuit fuse may be blown. It kills the frequency valve's function. It will idle but falter, stumble and pop when you give it gas. Mine is doing that now. Once you have experienced this a few times, you check the fuse, pull and re-install the Lambda box relay (little cube relay under passenger seat connected to Lambda unit). Fuse is third or fourth one towards front bumper from driver's position. Black cover will say OXY on it for the location.
1981 911SC Targa
Old 04-26-2017, 02:53 PM
Bob Kontak's Avatar
Dennis
Ernie
Sweet.
1981 911SC Targa
82 911 SC - Ancora Imparo
Sorry to resurrect an old thread but I'm getting ready to install my Streetfire.
I was planning to run the power cable to the rear fuse panel, but I know I could also run it directly to the starter power connection. Any benefit to running it directly to the starter as opposed to the rear fuse panel? Obviously running it to the starter is a bigger pain in the butt.
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 04-02-2020, 12:50 PM
RUN IT TO THE STARTER! I like to put an electro capacitor in th circuit too.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-02-2020, 10:06 PM
Someone I trust told me there’s really no benefit to running it to the starter. What’s your rationale?
Ethan
Old 04-03-2020, 06:28 AM
