55w/100w PIAA fog lights - worth it? Comments please.
Good Day,
I have had my 911 since 1998, this is the first fog light bulb that I have replaced! Don't make them like that anymore I am sure. Question: is the PIAA 55w = 100w a good investment? Do oncoming drivers flash you because they are too bright? Stock wiring? Thanks for your thoughts, Dave
1984 Porsche 911 Carrera 2002 BMW R1150RT 2013 Audi A4 2020 Ford F150 4x4 |
So these are h3 55watt bulbs that are advertised as being as bright as 100watt bulbs? If so, should work fine -- circuit is designed to work with 55watt bulbs, so no real difference.
That said, keep in mind that fog lights are not designed to project much of a beam -- instead, the project a very short (but wide) beam just over the road surface to help illuminate the road in very foggy conditions. Brighter light is not necessarily better for this specific situation. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Another consideration is the state of disrepair your fog light lenses are in. Either way, I don't envision any issues for oncoming traffic.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Darrin, yes 55w = 100w output. Pelican has them here on their web site. Might just clean up the lenses and go with the stock h3 55w.
I use mine as DRLs. Has anyone found a LED bulb that fits as a plug in replacement?
Juergen |
El Duderino
Short version. Trying to make the fog lights more useful is a waste of time. They are marginally useful at best. The PIAA bulbs are mostly marketing gimmick. The bluer light fools people in believing that they work better. Bluer light scatters more. Do a little googling on this topic and you’ll find a ton of info debunking the PIAA bulb marketing. I spent some time looking for decent LED DRLs and never could find something that didn’t look too modern or was designed for a truck.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 08-29-2019 at 11:57 AM.. |
And depending on actual conditions, you could find that you get best visibility with city/parking lights, as dips and/or fogs produce too much glare... That's pretty extreme though, and the speed involved was about walking pace...
'77 S with '78 930 power and a few other things. |
abides.
I never found the stock fog lights very effective, and i don't think brighter bulbs would have helped that. I replaced mine with some Hella driving lights and moved the relay connection over to the high beam circuit. Really lights up the road on a dark night.
Graham 1984 Carrera Targa |
Thanks everyone for your input. GTC - the Hella DL's come on with the high beams or with the low beams?
Dave
Find Spoke's LED Products: www.spokeworksled.com |
How much is a set? Mine is a ‘86 and I use them as DLRs
Juergen |
The set will be $165 a pair. I'm not satisfied with the light pattern from the LED lenses as they allow more light vertically than I would like to see. They would be great for DRLs but for foglights I'm just not happy with the light pattern. I'm investigating using larger lenses with tighter light pattern but wouldn't be able to put 4 LEDs in a row.
LED Blubs
H3-W13 LED bulbs fit. Available from superbrightleds.com
I couldn't find the H3-W13. I did find the H3-W14.
https://www.superbrightleds.com/moreinfo/led-drl-replacement-bulbs/h3-led-daytime-running-light-bulb-with-focusing-lens-400-lumens/5534/12490/ How did the lights work out for you? How did the light output compare to the H3 halogens? Noticed in the reviews that SuperbrightLEDs commented to several reviews that these were not head/fog lights and were DRLs only. The LEDs I'm working on are 2x as bright as the halogens on my car; both measured with new glass lenses.
LED Fog Lights
Hi Spoke,
Sorry, typo should have been W14. I use them for DRL only, very blue light. I have not tried them for night vision but my guess is that they would be pretty much useless. Looking forward to your version. I have your led brake lights and really like them. Brett |
abides.
Dave, the stock fog light wiring is set up so they come on with the low beams. You can move a wire in the fuse box to the high beam circuit so they will come on with the high beams instead. Driving lights would be too bright to use around town with low beams.
