flatable's Avatar
Camber when lowering Porsche?
I bought new rims, and was planning to have tires mounted and then lower the car. It appears to me (attached picture) the rear rims (9x16) are 1/2" too wide. My question is when I lower the car (not drastically - trying to get to a better stance with tire just under the wheel well - less gap) will the camber change enough to bring the rim in? Or should I return the 9x16s and buy the 8x16s and move forward? Any thoughts?
Old 09-01-2019, 11:57 AM
LJ851's Avatar
9X16 Fuchs fit with room to spare on SC/Carrera rear flares.
Old 09-01-2019, 12:13 PM
Bill Verburg's Avatar
If they are Fuchs 9x16 ET15 then they should fit an SC/Carrera w/ room to spare, w/ 245/45 tires, if they don't then check for damage or misalignment when the wheels are hanging the droop does cause a lot of positive camber that will go negative when weight is put on them.
camber spec in back is -1°+/-10'
you can run that or even a tad more negative
Bill Verburg
Old 09-01-2019, 12:43 PM
flatable's Avatar
Thanks Bill< I appreciate the details.
Old 09-01-2019, 01:25 PM
flatable's Avatar
Thanks LJ851
Old 09-01-2019, 01:26 PM
Flojo's Avatar
as the 9x16 et15 are similar to 8x16 et 11,3 I can give you my references:
my SC is lowered to 63cm (floor to top fender arch) and ist set to camber -1,05 to do the job in case of fully bottomiming in.
fender lip slightly rolled. no spacer. tire is 225/50-16
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-04-2019, 01:52 AM
flatable's Avatar
Yes, this is what I am hoping to get to! Great stance, I've seen your car on Instagram. Thanks for the measurements and tire size, they are useful as a benchmark.
Old 09-04-2019, 06:19 AM
Tags
camber , stance
