1969 911e Tach issues
I have a very original barn find E. My mechanic has completed engine and tranny rebuild, the rest of the car is staying with patina. My problem is the mechanic installed MSD, which I'm alright with. However, once that was installed he said my stock tach will no longer work. He put in a SC tach from another car in his shop, and it worked just fine. However, the SC tach has very white numbers not in sync with my other patina'd gauges. Can an E tach be modified to work with the MSD? Or perhaps can the face of the E tach be transferred onto the body and internal workings of the SC tach. Thanks for any advice.
I installed MSD in a 67 911 tach never worked correctly since . put stock tach back in !
Fb = M/S
You can have the SC tach face modified to match your E gauges. North Hollywood Speedometer and other shops can do this for you.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E |
Will they take my original E tach face and move it over to the SC tach body?
The best solution is to get a TACH-ADAPT from Bob Ashlock. I believe Pelican sells them. This will convert the MSD tach signal to work with your original tach and you will not have to modify your tach or any wiring.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Been here a while
Just to be clear. Your 69 never had white numbers on the gauges. They were more like ivory when new. A couple years later, the gauge markings became white.
Tach-adapt is a great solution.
looking for 1972 911t motor XR584, S/N 6121622 |
Correct they were more like ivory. The SC tach is clearly white.
Thanks for the tach adapt recommendation. Just spoke with Bob, and have one on order. Thanks guys.
Excellent!
Sent from my SM-G973U using Tapatalk
