CV Axles Question
Is there any special tools that can crimp the metal caps/back boot to the CV. The back cap that attaches to the rubber boot is loose on the CV and I’m afraid it won’t seal well. I tried using a rubber mallet but it’s not staying tight. How do people attach these?
I’m changing boots on 4 axles. 1 was a tight fit. This was not. http://forums.pelicanparts.com/uploa...1567529609.jpg |
Once you torque the Allen bolts it should pull it all together.
Bruce |
Just what Bruce said. On my 1984, these are not even used, as there is a gasket between the CV and the transmission flange.
Alrighty then. Just wanted to make sure grease won’t by flying everywhere at speed. Thanks
| All times are GMT -8. The time now is 08:18 PM. |
