Targa vs coupe differences
I have a 69 targa and it’s a project, I knew that.
It has way more rot than car now that I’m at bare metal, and the torsion tube is finished!
I have located a coupe chassis with a crashed front end that has almost no rot.
My front clip has never been hit and has minimal rust.
I want to bring the back of the coupe and the front clip from A pillars forward and make the two become one.
My question is regarding my doors.... are they much different than a coupe door?
I don’t have door glass and am wondering if glass and regulators differ from coupe to targa?
Also, my targa has a bit more sheet metal surrounding the passenger footwell area where heater tube emerges from the rocker panel. The coupe I’m looking at doesn’t have that extra layer of sheet metal and nothing has been cut or rotted away.
Is there a bit more added sheet metal to these areas when a chassis was destined to be a targa?
Old 09-14-2019, 06:03 AM
Quick answer. The Targa had added structural support for torsional rigidity to compensate for the lack of a solid roof. The doors differ in that the Targa’s have no window frames. I believe, but am not sure, that the glass itself is different. Someone else with much more knowledge will chime in.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 09-14-2019, 06:23 AM
Perfect answer, thanks.
My doors are mint and the donor chassis doesn’t come with doors so I wanted to make sure before pulling the trigger on the purchase
Old 09-14-2019, 08:26 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Think the doors are the same (not including the brace on the inside) The window frames are removable on the coupe doors.
Marc
Old 09-14-2019, 10:07 AM
Differences? Well the targa looks like a Targa. You know a topless 911 with a handle. And a coupe looks like a coupe.
the doors are the same.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 09-14-2019, 10:29 AM
Targas have structural re-enforcement at both rear sides (corners) of the cockpit. I can't recall with confidence, but I believe re-enforcements also existed on Targas at the two front corners of the cockpit as well. You can probably take a coupe and then weld in the sheet steel.
The rear fenders are also different... and probably the rear cowl.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 09-14-2019, 05:05 PM
Rescuer of old cars
Arne2's Avatar
From a legal standpoint, you may want to research how your local DMV will title/register the resulting car. Since the VINs are located on the A-pillar, front slam panel and the trunk floor near the smuggler's box, you could end up with mis-matched VINs (A-pillar from coupe, front clip from targa). They may require a state-assigned VIN and reconstructed/salvage title. If you are planning to keep the car when done, it may not matter much. But it could have a bearing on future sale of the car, and some insurers may balk at covering a reconstructed car.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-14-2019, 05:21 PM
Still here
pmax's Avatar
Yes, targa are for fun, coupes for serious business.
Old 09-14-2019, 05:54 PM
Banned but not out, yet..
RSBob's Avatar
Loved this answer. So Dick what’s the differences between a man and a woman?
Old 09-14-2019, 07:24 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Difference between the two? With a Targa, the driver can reach his hand out the window and wipe the taillight lenses clean, midcorner! Can't do that in a Coupe.
*Shameless plagiarism of the original observation by member, tirwin.
Old 09-14-2019, 07:30 PM
If this was Jeopardy, you win.
Old 09-14-2019, 07:53 PM
