Some of the alternate top mount options have a smaller bearing that helps a little vs the rubber donut in the oem plates.
Matt - 84 Carrera |
Drag Car of the 1960’s. It is starting to look like I may need New Strut Mounts Raise the Front of the Car Notch the Mounts to the Max. If I can get Mid to high 6’s then I can live with it.
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
Right now my Thought is to get the Bushing they sell ($100 for a set) And Remove the Strut Tops And Press In this new Bushing and then “KNOW” if that is really part of the Problem. My Hope is that just that will add maybe .5 to 1.0 to the Caster. Then the Rest is Easy! I really do not want to cut out that area unless I have NO Other choice. I am still trying to get over that my Cheap 1982 BMW 320i I can buy a Plate for under $100 and move that Strut to ANY degree of Caster and Camber. I am taking a look at a Mustang Strut Mount That has all Of these Adjustment and for about $75. I need to buy a Junk one and see what the measurements are.
Rescuer of old cars
That tells me that the rear is too high, or the front too low. Fender gap is not a really accurate way to measure (which I'm sure you know), but in general, a 911 that is sitting relatively level (or set to factory ride height spec) has a fender gap at least ˝" bigger on the front, often as much as 1". Fenders are cut out larger by the factory to allow for the wheels to steer.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
I just took a look and Feel. It has just about Equal Distance Between the Tire And Fender. So this WILL help the Caster if I raise the Front. Now I do not know if i am going to like the Look but if Raising it maybe 1/2” I can Gain .5 in Caster, then THAT is Exactly what I am going to do. (After some Research to KNOW where the car should be!! Thank you for bringing this up in a Way “Even I can Understand”!!
It's a 914 ...
You measured your garage floor or platform to make sure it’s flat, right (or use shims under the ties as needed)? It’s common for a floor that looks flat to be slanted 1 degree or more, which would obviously throw off your measurements by that amount.
I did buy a set of the KW ones, which have a unique design of putting the bearing flush with the plate instead of above it. Much smarter, as you can slip the bearing under the sheet metal further without modification to the tower. Small loss of strut travel is fair. Unfortunately, the design is also real dumb as you can't use them to get the camber they're designed to get without chopping up the plates. ![]() ![]() Not sure if these would hep you get the range you're looking for, but something like this might let you get away with modifying only the mounting holes and being able to leave that rolled lip center hole. Me, I wasn't comfortable modifying anything up there. I think the smartest product would be a top mounted bearing plate that moves in both axes, but that doesn't exist.
Matt - 84 Carrera |
You Truly have Been There and Done That! WOW What is the Brand of those plates Where did you buy them! How much? Thank you for posting this. BTW, it looks like for Camber Adjustment, you must make Marks on the Plates and make your Setting then Mount them “THEN” check your Camber. Then remove them and make more adjustments and remount until you have the settings you want. My thought is that they needed to do this USD so you could leave them mounted and make the adjustments Under the Tower.
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si Last edited by Vincent Hill; 09-17-2019 at 08:02 AM.. |
They're KW camber plates, I bought them from, uh, not our host.
Matt - 84 Carrera |
![]() ![]() I know they (our Hose does sell Elephant products. BTW, I raised the Front to its Max but not level so this reading is off By “0.5” so the real reading is 6.5
