-   -   Help w/ battery draining or alternator not charging (http://forums.pelicanparts.com/porsche-911-technical-forum/1040311-help-w-battery-draining-alternator-not-charging.html)
jpr2013 05-26-2020 09:09 PM
Thanks so much, darrin, super helpful. Guess I should run a search myself next time!
pmax 05-26-2020 10:18 PM
Originally Posted by jpr2013 (Post 10880372)
Anyone know a good alternator shop in Houston?
Same question for the SF Bay area. Anyone ?
darrin 05-27-2020 06:34 AM
no worries, our site doesn't have the best search engine and I was curious on what I'd find -- SURPRISED to find what I found :)
PMAX -- try this thread http://forums.pelicanparts.com/porsche-911-technical-forum/734697-need-alternator-shop-sf-bay-area.html
BTW, I've used google to find these (using the search "porsche alternator [cityname]") -- pelican posts came up in first page of results
sugarwood 05-27-2020 06:48 AM
Originally Posted by darrin (Post 10880363)
personally, I'd have the entire alternator and regulator assembly "gone through" by a (preferably local), old-school alternator repair shop -- that way, you'd also be comfortable that the diodes, brushes, rotor, etc. are good to go, especially given how recently your current one failed.
Also, I enthusiastically echo Dave's point above -- don't drive the car until the overcharging situation is resolved.
Do those places even exist anymore? Seems like a 1950s thing. Are they called alternator shops? How the heck does an alternator shop stay in business?? I have never seen one ever in my state. Have never heard of anyone using this.
darrin 05-27-2020 07:22 AM
sugarwood, where you live? happy to run another search for you -- there are quite a few of these still around -- my local porsche repair shop has also started doing these rebuilds/repairs themselves. Suspect demand stems from folks with classic cars (like us) and/or DIY folks that are/remain dissatisfied with the third-world rebuilds sold at FLAPS.
I continue to be pleasantly surprised at the number/nature of small business that continue to exist just off our collective radar.
tirwin 05-27-2020 09:30 AM
Look around... they are there. Sometimes it's part of a larger business. You know there are other things besides cars that use alternators, right? There is a shop right down the road from me that rebuilds alternators, starters, does small engine repair, etc.
pampadori 05-27-2020 12:19 PM
Every city has one or two. I'll explain our shop here in Richmond and you guys can compare it to yours and see if they are long lost brothers:
Very dirty run down shop with 1 or 2 bay doors and a small "waiting" area. Guy that runs the shop is part genius, part crazy possibly homeless middle aged guy. Not exactly an inviting personality but not directly rude either. Wearing the same pair of coveralls for the last 6 years with only a few wash cycles ever thrown at them. His hair is unkempt and greasy and his fingernails uncomfortably long and quite filthy. He is standing in the only part of the shop floor that isn't covered by the huge pile of old starters and alternators. There are literally thousands of them all over the floor.
Sound like your local guy?
This is an actual photo I took when I visited the alternator/starter repair shop in my town:
http://forums.pelicanparts.com/uploa...1590607138.jpg
jpr2013 05-31-2020 03:49 PM
Now the fan housing . . .
So I ordered the VR, pulled the fan housing . . . and discovered the housing is cracked. I assume these are not superficial or something I can just ignore?
http://forums.pelicanparts.com/uploa...1590964135.jpg
Based on what I've read elsewhere, I think I'll just nut up and pay for a new AL housing so I don't have to worry about fragile magnesium. Better to cry once.
I also discovered that the air guide that sits behind the alternator is cracked and was repaired with (maybe) an epoxy of some kind? Any opinions on whether you'd trust that or just replace it while everything else is out?
http://forums.pelicanparts.com/uploa...1590965400.jpg
911pcars 05-31-2020 04:35 PM
Stresses placed on the fan housing are usually due to.... an overly taut drive belt tension.
As for the air guide, I’d repair by adding some FG reinforcement. It’s only touched by airflow and indirectly by excessive rotational vibration.
Sherwood
jpr2013 05-31-2020 08:09 PM
Sherwood
Yeah, I was kind of surprised when I pulled the drive belt nut that all 6 of the shims were on the outside of the pulley half, which as I understand means that the belt is maximally tight.
jpr2013 06-08-2020 06:36 PM
I just picked up my alternator from Finch's Alternator and Starter Rebuilders in North Houston. They did good work for an incredibly reasonable price ($100) and a pretty quick turnaround. Now just have to get the new fan housing and the fan coated. Finch's confirmed that the alternator is basically "brand new" (guy said so a couple of times, like he was surprised anything had gone wrong). He'd tested it and with the new regulator it's putting out just over 14V (I think he said 14.2).
And Finch's is definitely a long-lost brother of your guy in Richmond:
http://forums.pelicanparts.com/uploa...1591666554.jpg
jpr2013 07-04-2020 02:33 PM
After getting the new housing and the old fan coated, I finally got everything reinstalled today and fired up the car. Voltmeter shows pretty consistently right at or below 14v, so all is well! Thanks to everyone who chimed in!
