-   -   Does hub centric = Lug centric as well? (http://forums.pelicanparts.com/porsche-911-technical-forum/1040426-does-hub-centric-lug-centric-well.html)
F1addict 09-18-2019 02:42 PM
So if I need to ad spacers that are 6-8 mm and that is beyond the hub centric lip will the lugs center the wheel since the minimum spacer with a lip is 15mm?
Toby
David Inc. 09-18-2019 02:55 PM
Never rely on lug-centric spacers. That's not what the studs are for. There are 7mm hub-centric spacers out there.
F1addict 09-18-2019 03:03 PM
The problem is the shallow spacers don’t have the lip for centering the wheel.
And from my research 15mm is the thinnest you can go to have a hub lip. I understand why, just wondering if the 911 lugs also center the wheel.
David Inc. 09-18-2019 03:21 PM
Elephant Racing does a 7mm hub-centric spacer.
F1addict 09-18-2019 03:37 PM
https://www.elephantracing.com/porsche/wheel-spacers/wheel-spacers-studs/
Looking at elephants website and a post by chuck I’ve come to This conclusion but could be wrong.... if your in the 8mm area your in no mans land. Not enough material to have a hubcentric spacer “with” a hub centric lip on it. Which is why I was wondering about if the lugs can act as a lug centric.
ian c2 09-19-2019 06:24 PM
H&r 7mm are definately hubcentric .
I moved a set in the garage a couple of days ago .
I’ll have to go look in the garage but I believe ruf are too , but porsche are not .
I think my next set up in size are 10mm and ruf . Hubcentric too .
gtc 09-20-2019 11:44 AM
Our ball seat lugs do a pretty good job of centering the wheel. I would snug the lugnuts evenly and call it good. If it's not centered for some reason, you'll feel the vibration right away. Just my 2 cents.
Sboxin 09-20-2019 04:15 PM
We have used some flat spacers and not had any vibration issues . . . agree that if the lugs are torqued properly the wheel should be centered on the hub - unless maybe the studs are all bent which is very unlikely . . . IMHO of course . . .
Good luck with your project,
Regards,
Roy T
AG81 09-20-2019 04:19 PM
X100.... but hey do whatever makes you happy.
chrismorse 09-20-2019 07:10 PM
Hub centric spacers take the shear loan, not the lugs
In another forum, there was a hot thread about the need to not just center the wheel properly, it is also there to transfer the shear load from the wheel to the hub, rather than placing a bending load on the studs.
chris
