-   -   REplacing voltage regulator (http://forums.pelicanparts.com/porsche-911-technical-forum/104169-replacing-voltage-regulator.html)
cstreit 03-28-2003 01:24 PM
My voltage regulator may have went bad. Can I get any regulator that handles the same amperage?
My car has a Motorola 70 AMP unit, but I can get my hands on a bosch 70 amp unit, will this suffice?
THanks
Tim Walsh 03-28-2003 01:25 PM
My car has a sticker on it to use only the same company for both VR and alternator. It could be wrong though alot can happen in 30 years
tryan 03-28-2003 01:44 PM
check out the ruddboys regulator posts on the 914 board. there is a generic unit thar plugs in to 3 prong plug. slice it and splice it.
jmohn 03-28-2003 01:57 PM
Which car? What year? Internal or external?
Jerry M
cstreit 03-28-2003 02:47 PM
It's a 1970 chassis, 83 motor, possibly a 74 alternator. No one seems to carry it.
MotoSook 03-28-2003 02:58 PM
The real question is will any regulator that can handle the amperage (say 70AMP) work?
Without getting into it too deep, wont a VR for most car work as long as the amperage load is higher enough? I am not a sparky (EE), but it seemed reasonable.
Chris' looks like this one:
http://forums.pelicanparts.com/uploa...marchal cs.JPG
cstreit 03-28-2003 04:42 PM
Well bit the bullet and ordered on because no one local has it. Another week down the tubes while I wait.
It is clear from opening it up that the only failed part of the regulator is a 5 cent capacitor, but in the factories wisdom they saw to covering the part up with some goop so you can't read what SIZE it is. So it costs me an additional $70.95 because of the darn epoxy crud on it. (*&$@#()*&$!!!!
boyt911sc 03-28-2003 05:52 PM
Voltage Regular from '78SC
Chris,
I have converted to alternator with integrated VR. The spare voltage regulator is similar to that on the picture posted by Souk. You can have it.
cstreit 03-28-2003 06:17 PM
Boyt911sc. I can definitely use it. I'll contact you off list...
I've ordered the part already so if you think you might need it for any reason, I'll understand. Otherwise as a thank-you, I'll be happy to at least send you a signed version of one of these:
http://forums.pelicanparts.com/uploads/cg17porsche.jpg
