-   -   Oil lines tapping inside front fender making clunking noise on bumps (http://forums.pelicanparts.com/porsche-911-technical-forum/1042216-oil-lines-tapping-inside-front-fender-making-clunking-noise-bumps.html)
nippy 10-09-2019 02:12 PM
Anybody have this problem? I have had 2 cars with the ER finned oil lines and both have had the same noise in the front fender. I took the wheel off and can duplicate the sound by grabbing the oil lines and pushing up and down. It seems like they are such a tight fit up top that they may be knocking against the inner fender. Just wondering if anybody else has noticed this. The noise happens on the smallest of bumps like a manhole cover or driveway lip. Very annoying and it clunks on compression and rebound of the suspension.Thanks.
john walker's workshop 10-09-2019 03:56 PM
How about a strip of rubber and some zip ties?
Sebscst 10-09-2019 04:26 PM
^^^ I have the ER finned lines and that’s exactly what I did.
nippy 10-09-2019 04:37 PM
I assume yours made noise to?
Sebscst 10-10-2019 09:42 AM
No I did them when I installed them as a saw how it would be a problem with rubbing against the fender. They are pretty solid and don’t vibrate or move .
nippy 10-10-2019 10:50 AM
Ok thanks, Ill give it a try.
