shh-the robot is sleeping
Distributer cap 4K miles, Thoughts?
I am trying to resolve stumbling at 2500-3500 rpm. Starting simple and noticed that my distributor and rotor seemed very worn. Is this normal ware after 4K? I sanded down these contacts and the rotor. Will take it for a drive ASAP.
'88 911 Coupe, 69k miles
Old 05-21-2018, 07:41 AM
Old 05-21-2018, 07:44 AM
Old 05-21-2018, 07:45 AM
ADDvanced's Avatar
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 05-21-2018, 07:48 AM
Normal.
206 637 4071
Old 05-21-2018, 08:09 AM
Originally Posted by john walker's workshop View Post
Normal.
Runs much better after sanding down the contacts but still not 100%.
Is that “normal” and replace or “normal” ... and look for something else causing the bucking at speed?
Old 05-21-2018, 09:31 AM
Should I replace this with a new one or look for additional issues?
Old 05-22-2018, 12:55 PM
Send a message via Skype™ to kyngfish
How old are the plugs? Wires?
May sound like a dumb question, and I only have my anecdotal experience to back this up, but have you made any other recent changes to your car?
I'd do the following:
- get it nice and hot, and then run it up to redline a few times in a safe space - I try to do this with my car once a week.
- doesn't hurt to replace plugs and wires as well as cap. Some people go for ultra premium wires, I wouldn't.
Do all of that progressively instead of all at once, to isolate the fix (if that fixes the issue).
I was getting occasional hesitation under load in the middle-upper rev range a while back, driving the s### out of the car fixed the problem, but YMMV.
I'll leave it to more experienced guys to dispense more advice.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 05-22-2018, 01:24 PM
Chain fence eating turbo
Assume a 3.2? This issue seems to be very prevalent.
Old 05-22-2018, 02:14 PM
SalParadise's Avatar
What?!?!? Is URO making caps and rotors now?
Never mind, all the Bosch stuff seems to be made in the Peoples Republic of China anyway.
I had one instance just like this. It was a cap and a rotor that had about 1K on it on my Series Land Rover. For the life of me I could not figure it out. It really was the cap/rotor, even though it looked OK. Replace them both.
Old 05-22-2018, 02:17 PM
Yes 3.2.
All plugs and wires were replaced 4K ago with cap and rotor.
Old 05-22-2018, 02:23 PM
DanielDudley's Avatar
Stumbling can sometimes lead to the AFM, especially if it is always at certain RPMs. If you take it out on a long road, you can hold it in one gear and slowly work the throttle up and down through the RPMs. A stumble from the air flow meter will always be remarkably consistent. When you are taking it through the gears it will see more like a random stumble, but when you work it up and down the RPMs slowly it will always come in around the same throttle position and RPM.
Old 05-22-2018, 02:39 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I don't think it is an issue. Dust off the cap contact points and move on.
1981 911SC Targa
Old 05-22-2018, 06:47 PM
I meant stumbling in the 2500-3000 range.
There’s lots of threads on this including my own.
Never figured mine out after 6 months.
Old 05-22-2018, 07:04 PM
DerkPerk's Avatar
Is that a Porsche cap or other?
Old 05-22-2018, 09:10 PM
Porsche Genuine Part - $179.00
Old 05-23-2018, 04:49 AM
T77911S's Avatar
just get a bosch cap.
sand or cleaning the contacts of the cap may only work once. tried it before. ran much better when I put new cap on but then mine had a LOT more miles on it than yours.
I think the gap from the rotor to the cap gets too big.
yours looks fine BTW.
as mentioned, could be tracks on the AFM, very common.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-23-2018, 05:17 AM
Thanks, T77911S. I am reluctant to open the AFM. AT this point, I think I will replace cap and rotor, clean out the throttle body, and give the engine a good look over for vacuum leaks etc... before diving into it. Also, at 70K I would think it is too soon for the AFM. No?
Old 05-23-2018, 06:19 AM
T77911S's Avatar
check the torque on the intake bolts while you are at it.
RACE CAR:: sold
Old 05-23-2018, 10:17 AM
Mine was getting sluggish in the middle revs due to carbon build up. Once hot and revving, it blew out a few clouds of black smoke under load and hesitating and stuttering, and then never had another problem.
This isn't to say there isn't an underlying problem. I'm fairly sure I have a small leak somewhere and that I'm running rich - which probably lead to the carbon buildup.
But she doesn't stutter or hesitate anymore.
3.2 here as well.
Old 05-23-2018, 10:26 AM
