<insert witty title here>
Christien's Avatar
Should I replace my voltage regulator?
Drove up to the lake on Friday, noticed the headlights and dash lights would randomly get brighter then back to normal, completely unrelated to rpm. Ok, voltage regulator, I thought. Drove it over the weekend including some track time while carefully monitoring voltage (checking while idling with a multimeter) and battery temp. All good. Drove it home yesterday, headlights didn't change brightness once. Should I still replace it, or was it maybe just a one-off thing? Similar weather/temp, if that makes a difference.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 10-15-2019, 10:33 AM
I'd presume your vr/alternator is failing and replace -- when mine failed, the voltage spikes were pretty random and since I didn't know better, ended up frying my tach and DME before I fixed. Now run a voltmeter all the time (via my cigarette lighter) so I can detect my next failure
Old 10-15-2019, 10:43 AM
Barrpete's Avatar
Probably the VR is going bad. You can get a meter to plug into the cigarette lighter like darrin mentioned for pretty cheap if you want to verify. That's what I did when I had the same symptoms you're describing and sure enough voltage would be normal/steady and then jump to 15+ volts for a few seconds. You might consider getting alternator rebuilt once you have it out of there as well.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 10-15-2019, 11:23 AM
Vintage Owner
Jack Stands's Avatar
Voltage Regulator
It’s cheap insurance.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-15-2019, 04:47 PM
Christien's Avatar
Ok, thanks guys. I'll pick up a voltmeter and keep an eye on it.
Old 10-16-2019, 10:39 AM
I'd recommend that you first check your battery and the area around/below your battery for moisture/evidence of overcharging -- these voltage spikes canl cause your battery acid to "boil" and damage the surrounding area. If you see any evidence of this, I'd recommend not driving the car until you have your alternator/vr rebuilt/refurbished.
Another "tell" of a failing voltage regulator can be phantom illumination of seat belt warning light -- again caused by voltage spikes. My concern here is that your vr may have been letting your charging voltage spike for quite some time (especially if you're not always driving with the lights on) and I experienced first-hand how continuing to drive with these voltage spikes can damage a variety of electronic components.
Old 10-16-2019, 11:09 AM
T77911S's Avatar
a lot of parts stores will test the charging system for free.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-17-2019, 03:06 AM
