Carrera engine oil drain plug washers
My car has an aluminum washer drain plug in the crankcase plug and a copper washer in the oil sump. Both are 22x27x1.5mm. Pelican only carries Al washers. What do the experts recommend?
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 10-15-2019, 04:24 PM
I've used aluminum for both for a while w/o issue -- change my oil out annually, and haven't seen any issue using an aluminum one on oil tank.
Old 10-15-2019, 05:08 PM
I found Copper 22x27x1.5mm (cheap) HERE.
Old 10-15-2019, 05:11 PM
can get both cheap at mcmaster carr
Old 10-15-2019, 06:32 PM
They are interchangeable.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-15-2019, 06:41 PM
They may be, but originally the crankcase washer was Al and the sump was Cu. Thee must be a reason, either electrolysis or torque value.
Old 10-15-2019, 06:45 PM
walt's Avatar
I've used both over the years, never an issue with either.
Walt
82SC 3.0
81SC 3.6
Old 10-16-2019, 06:01 AM
You cannot get electrolytic catalyst reaction with a washer immersed in oil. I have used copper against aluminum, and steel for years and nothing has ever gone bad.
Old 10-16-2019, 06:41 AM
proporsche's Avatar
i have always used only alu seals..both option numbers are for alu washers no copper listed anywhere i can see in PET..
Ivan
ps .but copper works as well as alu..
1985 911 with original 502 191 miles...808 198 km
Old 10-16-2019, 11:58 AM
HUH?? Common sense says that either will work.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 10-16-2019, 12:11 PM
AutoBahned
RWebb's Avatar
Common sense would inhibit a lengthy anal-retentive technological debate.
If any Common sense is to be used here, then let's hold off until this thread is several pages long.
Old 10-16-2019, 12:15 PM
theiceman's Avatar
...lol .. this actually got a thread ... hahahaha . you guys have officially run out of things to debate..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-16-2019, 12:17 PM
proporsche's Avatar
theiceman..there is no hockey on TV;-)
Old 10-16-2019, 12:23 PM
I like these threads, because inevitably someone will chime in with something useful.
For example, shopping mcmaster carr for these washers! Obvious in retrospect!
Old 10-16-2019, 03:12 PM
It may not make a difference and I am sorry to have ruffled feathers but the PET part numbers are different:
Sump washer - 900 123 011 20. It was always copper in my car when supplied by PAG.
Crankcase washer - 900 123 118 30. Aluminum.
It may not make a difference, but those were the OEM specs.
Old 10-16-2019, 04:34 PM
