17x7 wheels on a narrow body
Hi
Is it possible/advisable to put 17x7 wheels on a 911 -74 narrow body ? Pictures would be nice. Thanks |
Possible? Not likely. Advisable? Not at all.
Ass-engine Nazi slot car -- PJ O'Rourke |
I would rather be driving
Yes, as long as offset is correct.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
7x15 205/60 x15 certainly fits at all 4 corners of a 911 n/b from '69 -77 total width is nominally 205mm nominally but stretches to more like 213mm on a 7 total height is ~24.7" axial placement depends on wheel ET which for a Fuchs 7 is 23.3 so say you want a 7x17 use ET23.3+/- there is a little wiggle room here use a 205/45 x17 tire total width ~206mm on a 7 total height ~24.3" This fits w/i the envelope of the 15 and is axially placed in reasonably
Well, the actual wheels I am looking at are specified with offset ET40. They are Fuchs replica.
I bet these wheel configuration have been tested before, but I can not find any on the forum. |
ET40 moves the wheel/tire assembly 16.7mm further inboard than is good for a 911 fit, you could move it back out w/ 16.7mm spacers
