47silver's Avatar
Use ignition gease on the nylon block just a dab on the leading edge
Old 10-26-2019, 02:27 PM
1973.5 911T
Thanks for all the great info everyone.
To confirm, the ignition point gap on this car 1973.5 with CIS should be .016 in?
Gilbert
1973.5 911T
Old 10-27-2019, 07:27 PM
E Sully's Avatar
The gap is just a starting point, and I believe it is .014, .35mm. As stated before, the important thing is setting the dwell.
Here is a thread of mine on distributors. It also contains links to other good threads concerning distributors. The original distributor can be replaced with no issues with later '74-'77 distributors. I used one from a '77 for a few years. I currently use the original 0 231 169 008 (73.5 T w CIS) specific distributor after re conditioning it. https://forums.pelicanparts.com/porsche-911-technical-forum/692119-distributor-maintenance.html
Timing will need to be reset after setting dwell.
Ed
1973.5 T
Old 10-28-2019, 08:31 AM
1973.5 911T
Thanks Ed,
I got a hold of a "vintage" dwell meter from the local classifieds to be sure of the dwell angle.
Was wanting to confirm the point gap as I have seen .014 and .016 on different manuals.
You guys get dwell angle with the engine running correct?
One wire to a ground on the fan and the other to the connection from the points at the distributor.
Correct?
Gilbert
1973.5 911T
Old 10-28-2019, 08:52 AM
HarryD's Avatar
Originally Posted by GJVGC View Post
Thanks Ed,
Sounds about right for the initial setting. Dwell meter is the final setting.
Correct?
Exactly.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-28-2019, 09:33 AM
1973.5 911T
Got a dwell meter.
Set the point gap to .014 and the dwell meter is reading 36degrees.
Manual states it should be 38 +or- 3.
Better to be above or below the 38 degrees? Any difference there?
Gilbert
1973.5 911T
Old 10-30-2019, 04:58 PM
HarryD's Avatar
Got a dwell meter.
Dwell increases as the rubbing block wears. Too low is a better starting point.
Harry
2020 MB E350 4Matic
Old 10-30-2019, 05:40 PM
