3.2 Cold Air kit
I searched for it...very surprised not to find anything.
I see many 3.2-ish owners out there with a K&N or similar kit replacing the stock airbox. Looks like Pelican's is no longer available. Any recommendations on someplace else to look into it?
Here's Pelican's...reviews not ideal either but...hummm...
https://www.pelicanparts.com/More_Info/PELINTK911.htm?pn=PEL-INTK911&bt=Y&fs=0&SVSVSI=805
Many thanks!
Current:
1984 911 Targa Whale Tail "Gemma"
2014 Boxster S (wife) "Sir Jenson" (She named it...not me)
Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4
Old 11-12-2019, 06:13 PM
The 9 Store
It's no better than stock. The stock air filter is not a choke point. Don't believe the hype.
Old 11-12-2019, 06:51 PM
But...but...but...it's so...pretty!!! (zipping up flame suit in preparation of being nuked...)
Current:
Old 11-12-2019, 06:54 PM
No such thing as cold air intake in a 911.
Unless ambient temps are cold. YMMV.
Pelican's equiv. setup: parts are in ebay
Sherwood
Old 11-12-2019, 07:26 PM
Really no point for a cold air intake. The cooling fan does a great job keeping the engine bay filled with cool air. Porsche provided pretty good stock intake piping on the air boxes.
Old 11-12-2019, 08:20 PM
New OEM paper filter and bore some large holes in the lid. Flows fine according to my manifold pressure comparisons and gives great induction noise over 3,500 rpm!
From what I have seen putting a K&N on a street car is a form of mechanical abuse as every one that I have seen has had a layer of grit on the inside of the intake manifold as no one seems to properly maintain cotton gauze filters.
Old 11-12-2019, 10:27 PM
RETIRED
Joe Bob's Avatar
On a n/a motor? Snake oil.
2012 ML350 3.0 Turbo Diesel
Old 11-12-2019, 11:06 PM
What they said. The stock one is good enough.
Old 11-13-2019, 12:43 AM
Brew Master
cabmandone's Avatar
Probably easier to change the filter but no real benefit beyond looking cool.
Nick
Old 11-13-2019, 03:16 AM
shawn908's Avatar
Where to find? I found one here on the used parts forum. Try posting a WTB advert. No downside. Love it!
Old 11-13-2019, 05:39 AM
I'm good with tools.
AG81's Avatar
Do some measuring and look at K&N's site for parts that will work.......
If that's what you want to do........
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-13-2019, 06:00 AM
911tracker85's Avatar
if 'cool' is what you want I may have your solution. I do not think I sold it.
a custom air horn and K&N filter I had on my 3.2, sold the car last year.
that was before I became more educated on this stuff. NA stock 3.2, paper filter works fine. 600hp race engine ... another story.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 11-13-2019, 06:16 AM
Psychepilgrim's Avatar
Cold air intake
Exactly what I'm looking for if no one else want's it!
You have a PM.
Behind the wheel in my US imported 81 SC with 3.2L swap.
Old 11-13-2019, 07:22 AM
Forest Gump: "Stupid is what stupid does"
Old 11-13-2019, 08:53 AM
Psychepilgrim
replied to PM.
at one point I may have been ignorant but I am not stupid. BIG difference.
Bob Cox
Old 11-13-2019, 09:22 AM
The latest versions of cotton gauze filters are currently dry (oil-less), probably due to complaints of excess filter oil compromising air flow sensors.
The factory 3.2 air box interfered with my early oil filter/oil tank, so I sourced the largest AEM filter that would fit inside the engine compartment. It's a 10" cone canted at 45 deg. (shown without the prefilter sock).
Sherwood
Old 11-13-2019, 10:44 AM
shawn908's Avatar
Sherwood
Thanks for this additional detail. Helpful and instructional to my use of the Kolken (and probably any others too) intake tube and filter.
Old 11-13-2019, 11:25 AM
Take the oem cover and cut it. Costs nothing and uses the standard filter. It does nothing for performance, just like all those other filters but sounds nice. Also makes the filter change much easier because the back toggles are easy to get at.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 11-13-2019, 02:29 PM
gtc gtc is offline
abides.
gtc's Avatar
MSDS sells one that works well if you taper the adapter inlet - it comes as a pretty rough cast aluminum piece. I picked one up a while ago on Steve Wong's recommendation.
Graham
1984 Carrera Targa
Old 11-13-2019, 02:36 PM
Cory M's Avatar
I've got this machined aluminum adapter to fit a cone or cylindrical filter to a 3.2 engine. The diameter of the plate is approximately 125mm or 5 inches so it fits a lot of different filters. I don't have the filter but Summit Racing sells several options. The only thing you have to verify is that the length clears the decklid hinge. I swapped engines and can't use it. I'll take $30 shipped, if anyone needs it send me a PM.
Old 11-13-2019, 09:37 PM
