Car Care Products
I know this is probably not the best place to post this but I've looked thorough other posts and can't really find anything. I'd like to know what other people use to keep their cars looking good. Hopefully, there's some kind of general consensus. Right now, I want to protect my door seals (I have an '88 3.2 Carrera) which are still in good shape. I'm concerned though about the rubber seals between the cowl and front fender, at the base of the "A" post, which are starting to harden . Ideas?
Old 11-17-2019, 10:43 PM
For rubber Nextzett 'Gummi Pflege Stift' Rubber Care Stick.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 11-17-2019, 11:52 PM
Ctopher's Avatar
I use Honda Shin-etsu Silicone Grease on all my rubber seals. A little goes a long way.
CTopher
Old 11-18-2019, 07:58 AM
Under the radar
Trackrash's Avatar
I've been using baby oil on all my rubber seals for years. Keeps them soft.
As far as the seal between the fender and cowl goes. I don't think that is rubber?
Have you tried asking in the Paint, Bodywork & Detailing Forum - Pelican Parts Forums ?
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-18-2019, 10:42 AM
Either the Nextzett, or the Shin Etzu silicone products (both mentioned above) are the best to use. Basically, anything with silicone is the way to go. The door seals are EPDM sponge rubber, and any petroleum based oils will not be good along term (especially sulphur-cured EPDM, which they most likely are). They will eventually swell and the process oils in the rubber compounds will leach out. Silicone is inert, and will not have that effect. I am not as familiar with the cowl seals; but they may be a thermoplastic (TPV or TPE, stiffer durometer), and are naturally harder. The silicone will help in any case, though.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 11-18-2019, 01:02 PM
thanks everyone for your advice!
Old 11-18-2019, 02:48 PM
Administrator
Dmitry at Pelican Parts's Avatar
Nextzett Gummi Pflege Rubber Protection
Old 11-18-2019, 04:18 PM
Areospace 303. Full stop. It was designed to condition the seals in the space shuttle.
Use it on everything rubber, vinyl, plastic... except your tires. You don't want them "jet fooking black"
Glycerine - the kind you get from a drugstore - is also good for seals. It's a plasticizer, and dry seals will suck it up.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 11-18-2019, 07:32 PM
freesaints's Avatar
Shin-etsu Silicone Grease on all rubber trim/parts and Aerospace 303 on all vinyl in the interior.
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 11-19-2019, 06:25 AM
