| Registered |
				What's in my airbox
			I am doing a little maintainence on the Porsche this weekend. I noticed some small black pelets in the bottom of the airbox. Any ideas?
				__________________ '87 911 Carrera Coupe | ||
|  03-29-2003, 11:15 AM |
| Registered |
			Are those holes drilled in the top of the airbox?  That could be your answer ... IPO!  AKA -- Idiot Previous Owner ...
				__________________ Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' | ||
|  03-29-2003, 11:21 AM |
| Registered |
			No holes. The stuff is not plastic. It is heavier, like graphite or something. It seems like it is there for a reason, but I can't imagine what it would be.
|  03-29-2003, 11:26 AM |
| Back in the saddle again Join Date: Oct 2001 Location: Central TX west of Houston
			could those be animal related??  waste?
				__________________ Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa  SOLD 2004 - gone but not forgotten | ||
|  03-29-2003, 11:48 AM |
| Registered Join Date: Nov 2002 Location: gatlinburg tn
			texan mouse droppings?  taste one ( just kidding , that stupid 78 garage targa tasting the acidic oil cracked me up )  grab a handfull and post a close up.
				__________________ 72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday | ||
|  03-29-2003, 11:53 AM |
| Registered |
			I wondered why it looked like something had been nibbling on the air filter.  Nope. It is definitely not animal related. Here is another pic. Thanks.
|  03-29-2003, 12:05 PM |
| one of gods prototypes |
			had the same thing in mine when i first bought it, it seemed to be related to the aftermarket filter (the glue resin stuff that seals the filter material to the rubber gasket) i switched to an oem porsche filter and haven't noticed any of that since. take a GOOD look at the filter that was in there........
				__________________ Brought to you by Carl's Jr. | ||
|  03-29-2003, 12:13 PM |
			i have had mice eat into unopened boxes of poison and make secret stashes in the cars. at moms house, we thought the 15# dog was eating 50# a week untill we looked in the boots in the closet next to the bowl. shop vac that stuff out. if they did not eat through the air filter, i would not worry. we now have IPR. idiot previous rodents. must be french.
|  03-29-2003, 12:14 PM |
| Registered Join Date: Dec 2000 Location: McLean, VA
			Dram, That, my friend, is charcoal that has migrated from the charcoal canister tucked up high in the front of the pass rear wheel well. It is part of the dread emissions control system. These little buggers are DANGEROUS. Get a few past your air filter into the engine and they cause baaad things to happen. They must go! Carefully vacuum them out of your airbox. If you think it is possible that a few might have snuk past the filter while you were poking around, pull the rubber boot off the throttle body and vacuum the little devils out of there too. Next thing to do is disconnect the line from the canister to your airbox. OK, its not the greenest thing you'll ever do, but do it. Tuck the line away and let it vent to atmosphere. DO all this before starting your engine again. Did I mention that they will hurt your engine if they are ingested?
				__________________ Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site | ||
|  03-29-2003, 03:26 PM |
			ahh the ole charcoal pellets trick.  do the hoses allow injestion past the air filter?  are replacement canisters available?
|  03-29-2003, 03:53 PM |
				 | Quote:
 Everything downstream of the airfilter is optimised for high volume airflow. First time you go WOT, any pellets that make it to the duct get a 350CFM rocket ride straight into the top of your engine. Definitely baad boogie. Replacement canisters are available from PCNA spares.
				__________________ Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site Last edited by APKhaos; 03-29-2003 at 04:22 PM.. | ||
|  03-29-2003, 04:00 PM |
			the charcoal canister on the 914 is plumbed to the engine side of the air filter.  the canister is fine ,but the rubber line is delaminating internaly. the rocker panel has to be removed to replace the line.  i have a cotton ball and a screen in the line now, because the cars are stored in the basement/garage. ( no fumes allowed )
|  03-29-2003, 04:20 PM |
| Registered |
			Thanks for the info. I have vacumed everything out good. I will goahead and disconnect the hose. This definitely looks like trouble waiting to happen. Don
|  03-29-2003, 04:35 PM |
| Registered Join Date: Jul 2001 Location: Lenexa, KS. USA
			I found the same thing in mine the other day. Looks like I will be diconnecting the hose as well. Will everything run ok w/o this hose plugged in?
|  03-29-2003, 05:51 PM |
			OK, if you are going to disconnect the cannister hose...... - report yourself to your local EPA office - block off the barb in the airbox. Don't want unfiltered air coming in there. - drive happy
|  03-29-2003, 05:57 PM |
			Ok. This is how I solved the problem. Opened up the airbox and cleaned it out. Diconnencted the oultet hose from the Charcoal can and sucked it clean with the shop vac. Went to the local ato part store and bought a "performance fuel filter". Intalled it right after the outlet flance of the charcoal can. Now, if charcoal burps out again, it will be stopped by the filter, and I can see it.  The smog police will still be happy. (see before and after pics.) Total cost $10.     | ||
|  03-30-2003, 05:08 PM |
| Registered |
				No clue but mine has it too!
			I haven't opened the air box but have a bunch of the stuff around my engine compartment. Odd that this topic came up today. I just mentioned it to my wife the other day. Gordo
				__________________ Don "Gordo" Gordon '83 911SC Targa | ||
|  03-30-2003, 08:09 PM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			Would like to go back to early_S_man's comment....look at the original photo... Are there holes drilled on the *downstream* side of the airbox...topside ?? Holy smokes! ...it looks like it's drilled. --Wil Ferch
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) | ||
|  03-31-2003, 07:35 AM |
| Friend of Warren Join Date: Oct 2000 Location: Lincoln, NE
				 | Quote:
				__________________ Kurt V No more Porsches, but a revolving number of motorcycles. | ||
|  03-31-2003, 07:42 AM |
			Nice solution, SK. Thats a good way to keep the original cannister and prevent any further charcoal pellets being drawn into the airbox. Will, Mark: This is not a drilling issue - they are charcoal pellets delivered with the car. Just not staying where they should be!! What you are seeing in the top pic are the square webs in the casting which is the top of the AFM - behind the airbox.
				__________________ Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site Last edited by APKhaos; 03-31-2003 at 07:46 AM.. | ||
