too much oil
I had stored my 83 SC for about 5 months. I changed the oil just before storage, Upon start-up it smoked like crazy. A short run around the block and back into the garage to check everything visually. All looked fine so I started it up a second time and it seemed pretty normal. I took it for a good drive today 10-15 miles and did notice a small amount of blue smoke initially but none on my return. A read of the dipstick while hot showed I may have overfilled by 1/2 of quart. No blue smoke noticed at that point. Will I do any harm if I DO NOT drain off?
No particular problem.
You can anyway drain som oil using a big syringe connected to a tube from the oil tank or have your car run for a long spirited drive.
911 2.4T from 1973 Gemini Metallic Blue |
drain the engine case only ,that will be 3 liters or quarts..then run warm and fill it up with that oil .Leave about 5cm before the top mark on dipstick..If that drain plug seal is not too crushed reuse it but new one is always better..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-04-2019 at 07:56 AM.. |
Depending on where you live 10-15 miles may only get the engine warm. I'd leave it, you'll only make a mess trying to drain 1/2 quart. A little smoke on start-up is normal especially after sitting for months.
Walt 82SC 3.0 81SC 3.6 |
horizontal cylinders....a tiny bit of oil seeps past the rings when the engine cools and that's the blue smoke you normally see on startups after the cars sits and the engines cools. Nothing to worry about...totally normal.
1983 SC - sold 2002 996 C4S - sold 1968 912 |
boys he said..this...A read of the dipstick while hot showed I may have overfilled by 1/2 of quart...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Mine did this too. I had also just changed the oil then let it sit. The oil seeps by the rings and leaks out into the exhaust past an open valve or two or three. It will smoke like crazy until it burns off. You just have to drive it more.
Thanks all. so it will get a good workout. Everything seems fine now. Tomorrow I will take it over to Hilton Head Concours. About an hour each way!
Definitely don't run it overfilled though. You'll be sucking oil into the breather/intake. I'd follow proporsche's advice.
Will 1/2 a quart overfill create smoke ??
1986 Bosch Icon Wipers coupe. |
Formerly known as Syzygy
It's almost two quarts between the fill and full line on the dip stick. I'd empty the sump or use a turkey baster or a fluid pump to remove some oil. Add enough back in to get half way between those two lines when hot. No need to try to keep it near the top line.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Next time you store your car, refill with only 5 qts. and avoid all the smoke when you start it up. You'll even have plenty of oil pressure at that level, guaranteed!
i go 7l and then top up as needed .. .. never had an issue ..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
install a fumoto valve at the next change.
I used to overfill because my engine was never warm enough during oil changes. Now with the valve, i can just take out as needed without a mess. |
