-   -   End of year tune up (http://forums.pelicanparts.com/porsche-911-technical-forum/1044237-end-year-tune-up.html)
david.avrahami@ 11-03-2019 12:16 PM
End of year tune up
1987 Carrera
I am about ready to close another maintenance chapter which took longer then expected.
I want to install the valve covers 6 nuts on top, 11 nuts at the bottom of each side.
The security nuts that came with the a variety of other item as part of a kit seem to be the right size, BUT, mounting them is a challenge...turning require the use of a wrench and I have a hard time feeling comfortable that they reached the preliminary tightening prior to torquing them to 6 FT/LB OR 8NM as required...
I do have a good quality torque wrench and I tested it on another bolt elsewhere mounted already ...the the click was heard in no time...
I Tried torquing one of the cover nuts and I seem to go on and on but it seems the tightening was significant for only 6 ft/lb. and no click...
Any suggestions?
rwest 11-03-2019 04:44 PM
Hi David,
I’ve never put a torque wrench on my valve cover nuts, those things are not going to work themselves off with the plastic insert in them. I just tighten until the valve cover is seated and the nuts are snug. If they leak, then I will tighten a bit more.
Rutager
