Wider is Better
Mounting holes for hood emblem
my 87 911 was painted and the painters inadvertently filled in the mounting holes for the hood emblem. They were filled with filler and painted over. Is there a way to locate them using measurement or some trick to find them under the paint? I could not fine an exact location description in the factory service manual, google, or searching this forum. Thanks.
Wider is Better |
Can you poke through from the backside? If there is filler and fresh paint involved, maybe use a small hand drill to be safe.
Or, consider a crest decal instead?
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Open the hood there's two holes punched in the hood frame for speed nut access, you should be able to locate from backside. Get some painters tape apply to topside if paint is cured and use a sharp drill from backside.
Wider is Better
The car was painted about a year ago so the paint has fully cured. I have looked carefully for some dimpling on the underside of the hood but there is nothing. If I can get close to where the emblem should be, I think I can find the holes using a magnet, but I need an approximate location.
I would appreciate it if one of you would measure from the front of the hood to the bottom of your emblem. This will enable me to place the location within an inch. I will then tape a piece of clear plastic over that site, attach a large magnet I use to pick up screws to the underside of the hood and sprinkle some iron filings on the plastic. Theoretically, the metal hood should block the magnetic field, except through the holes filled with non-magnetic filler, and the filings should congregate over the holes.
Wider is Better |
Let us know if your magnetic trick works... I have the same issue on my 71.
Thanks, Karl |
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
ROW '78 911 Targa
Steel will become magnetic and hold the filings in place, the plastic filler holes won’t.
Holes are 5 inches from edge of hood
Wider is Better
kfosburg: I will post pictures.
MBATarga: Technically, Saran Wrap is plastic. My description was unclear but that is what I planned to use. timmy2: I was pretty sure this would work but it's been a long time since I studied magnetism :-) Dpmulvan: Thanks!
Wider is Better |
