Help with ignition lock problem
Been having a problem with the ignition switch on my '84 Carrera and was wondering if anyone else has had a similar issue. From time to time, I'll put the key in the ignition and it will not turn. I hesitate to put too much pressure on it because the Porsche keys are so thin. I have not turned the steering wheel to engage the steering lock, yet the key feels like the wheel is in the locked position. Any ideas?
show us the key condition of the key,,just do not use any wd 40 on it for now..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I have a second key. I'll trying using it for a while and see if it cures the problem.
cycling has-been
I don't need to see a picture of the key.
The flags inside the tumbler are all gunked up. Start by spraying a little PB Blaster, or Kroil, or even brake cleaner, on the key - continue to use. Repeat until the key engages correctly. Graphite grease will only make the problem worse. You need something inside the tumbler to start diluting the mounds of gunk. Patience. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 12-27-2019 at 11:30 AM.. |
Good advice, thank you. I'll try the spray method this afternoon.
cycling has-been
Keys, tumbler and flags.
Picture yours with 36 years of gunk on each of the 12 flags per cylinder. ![]() Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Don't use PB blaster in your ignition it contains oils which will attract dirt grime et. Tri flow is a good lock lubricant available at local hardware. If cleaning and tri flow doesn't work pm me I do a lot of locks and have spare cylinders, switches et.
83 911 Production Cab #10
Had that problem for a few years...
The "barrel" was loose and the Lock Out came on. Punch the two rivet and never had it since. Check Ignition switch springing problem if the second key does not fit the problem.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
cycling has-been
PB Blaster contains anywhere from 20-30% petroleum distillate which will dissolve built-up gunk - not attract it. Here's list of what makes up Tri-Flow - a lot more petro (oil) products than PB Blaster. Heavy Naphthenic Petroleum Oil 39.2 64742-52-5 Aliphatic Solvent 23.6 64742-47-8 Propane 10.2 74-98-6 Butane 9.8 106-97-8 Heavy Paraffinic Oil 3.4 64742-65-0 Heavy Naphthenic Petroleum Oil 2.0 64742-52-5 Barium Dinonyl Naphthalene Sulfonate 2.0 25619-56-1 Tetrafluoroethene Polymer 1.3 9002-84-0 Bill K
