915 nose replacement
Have a -74 911 with the mechanical speedometer tranny nose which I need to change due to the damage threads on the speedometer connection. The replacement nose is in-house, so I just need to remove the the axl and gears from the old nose to the new.
They seems very tight, so any idea how to go forward ?
Heat
I believe the illustration is of a 901 trans speedo drive, O.P. is asking about a 915 nose, where the threads for the speedo cable are notorious for breaking.
'56, '59 356A Coupes '67, '68 912 Coupes all gone '72 911T coupe |
If your challenge is getting the "dog bone" out, yes, it can be difficult. The magnesium case just loves to galvanically corrode to different metals. There is a circlip retaining (7) the steel (old) or aluminum (new) button plug (9).
![]() Remove the circlip, or more likely excavate what remains of it. Use some heat from the outside to warm the case around the plug, and tap the plug out with a long drift, working around its circumference to the extent possible. Install a new, uncorroded plug and o-ring. Last I checked, the alu versions of the plugs were available from Porsche: I have a few of them in stock. I hope this helps. Patience and some overnight soaking with penetrant will help some.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ Last edited by kevingross; 11-10-2019 at 03:46 PM.. |
