Targa_PB_78_SC
Door stop pin availability
Anyone know if the door stop pin is available?
My pins are not great, one works it’s way up and out over time, the other is too fat to seat properly. Talking about part in pic below
(man/dude)
It should be but Porsche seems to have discontinued the part in the PET without superceding it. Try googling part# 91153127500
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
6mm bolt and nylock nut. Tighten until the snapping stops.
Targa_PB_78_SC
Thanks john walker's workshop for the clever solution!
Thanks gomezoneill for the link |
Wound up modifying the stop detents to make them less stiff and used John Walkers's bolt suggestion. Works great now
1978 SC Targa |
Targa_PB_78_SC
I had the pin in the door fly out of hole today, and used a 6 mm bolt and lock nut. Very pleased with the result. Much better than those nasty pins!
